A8 Intake Actuator Arms
Haven't see a thread on this (did find an old one in the D2 forum) but found one of my intake actuator arms was broken. The only reason I went looking was a tip on another forum to "check them routinely" as they are prone to break. When broken you can experience a loss of power and maybe even a stumble at off idle acceleration.
Well sure enough, one is broken. Here is the option, Audi $700-800 for a "Kit" to repair/replace them, or: http://gruvenparts.com/website/cart/...category_id=60 I ordered a pair of them for $79 and they should be here next week. Here is more info from the VW website (Phaeton) http://forums.vwvortex.com/showthrea...ngine-TOC-done |
No harm done. We can't have too many information. :)
Gruven product is good. Just need to keep an eye on the shaft operation once installed.
Reason being is that the links are the weak point if failure of the shafts or butterflies occurs. But, sometimes the links just age and become brittle then fail, like in my case. Before you fit the links, manually rotate each of the arms to check of the shafts 'stick' or click or are very hard to move. If so, DO NOT INSTALL THE NEW LINKS. Rip the intake off and refurbish / clean out the intake and check why the shafts are not moving freely. Repair then fit the links. Cheers |
Thanks for all the tips guys. I checked mine today too, meant to do it when the most recent thread came up that mishear posted but forgot. Both shafts on my 2004 are broken. I ordered the gruvenparts shafts today.
Question, is there a trick to getting the plastic shafts off, or they just pop right off with enough pressure? Thanks. |
Originally Posted by AusA8
(Post 24293687)
Reason being is that the links are the weak point if failure of the shafts or butterflies occurs. But, sometimes the links just age and become brittle then fail, like in my case. Before you fit the links, manually rotate each of the arms to check of the shafts 'stick' or click or are very hard to move. If so, DO NOT INSTALL THE NEW LINKS. Rip the intake off and refurbish / clean out the intake and check why the shafts are not moving freely. Repair then fit the links. Cheers :-) The first thing I did was make sure the shafts where not binding or stuck, both move just fine. I think I am good, just a victim of the plastic failing. |
Originally Posted by boz151
(Post 24294015)
Question, is there a trick to getting the plastic shafts off, or they just pop right off with enough pressure? Thanks. http://i265.photobucket.com/albums/i...e/P1010329.jpg http://i265.photobucket.com/albums/i...e/P1010350.jpg |
(Post 24294015)
What size did you guys order? Going to check mines later but want order them now. Had mines for almost 5 years and I'm pretty sure one or both might be broken.
