AC blowing hot air
Must be late Spring...
Low refrigerant is the norm. Search on it.
Get it professionally filled. Any AC shop with the std. evac. + fill equipment can do it.
FYI.....I finally fixed my leak on my S8. I ended up using the AC pro stop leak. This year I put in two 375 gram containers of R-134a and it was no longer effective after two days. Year's ago one can would get me through the season. I bought the following:
Then I charged it after putting it in.....it's been about a month and AC works!!!!!
Not what MP4.2+6.0 wants to hear, but I am glad I don't have to drop the subframe and go after the compressor. It was leaking somewhere around there.
AudiWorld Wiseguy
It’s been beat to death over the years, but due to it having a variable capacity compressor, the A8 AC system is VERY sensitive to the correct weight of refrigerant being added to the system. 600g with +/- 50g tolerance (620g for W12 and 4.0 TDi). Small deviations above or below and it stops working. Only way to do this is with a proper evacuation, and recharge with the correct weight of refrigerant and compressor oil, as performed by a proper AC servicing machine. Less than $100 and with a warranty from virtually any regular shop like pep boys, etc.
Trying to save the cost of a half tank of gas by eyeballing it with a DIY refill can and gauges is a crap shoot, and will net you at best a partially working system, with the grand prize being a blown AC compressor.
https://ictworkshopsolutions.com/ict...ling-Chart.pdf
AudiDad15
05-25-2019 04:22 PM
Brown Water
09-17-2018 01:22 PM
