Sponsored by:
Sponsored by:
ACC issue - 00234 Misadjusted
Old 03-31-2019, 09:52 AM
W12BTW's Avatar
Default ACC issue - 00234 Misadjusted
Hi guys,
my ACC stopped working a week ago. Just stopped working and pulling the following error. Tried to clear the error but still coming on. I did also check the measuring blocks and this is what is recorded. It comes up with Error code on Group 1 ?
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041251
Shop #: WSC 02313 785 00200
VCID: 2517F333A9EB2BBFCDB-8070
1 Fault Found:
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110000
Fault Priority: 5
Fault Frequency: 7
Reset counter: 90
Mileage: 178716 km
Time Indication: 0
Date: 2019.03.30
Time: 13:17:00
Freeze Frame:
Temperature: 35.0°C
Voltage: 11.39 V
Bin. Bits: 00100000
Old 04-01-2019, 05:35 PM
Sci-fi_Wasabi's Avatar
This won't help you much right now, but I do want to know if replacing the module (the radar behind the bumper cover) will require component protection removal.
If you do try a replacement radar, let me know how it goes.
Old 04-05-2019, 10:06 AM
W12BTW's Avatar
Hi all,
just for all which might have the same issue. It just needed re-calibration which you can do if you have VCDS.
Thanks
Old 04-07-2019, 04:37 PM
summitradio's Avatar
Originally Posted by W12BTW
Hi all,
Thanks
is there any instructions on this recalibration procedure?
Thanks
Old 01-20-2021, 02:51 AM
Clairet Jeremy's Avatar
Default Acc
Hi all,
Thanks
Vous savez comment faire avec vcds merci
TeaMeTzu
06-19-2019 10:51 PM
stuffinder
08-10-2015 01:41 PM
PaulW
24
03-11-2014 05:18 AM
digitalci
Q7 MK 1 Discussion
12-02-2012 10:34 PM
DM-S4
02-18-2007 09:33 AM
Quick Reply: ACC issue - 00234 Misadjusted
