Adaptive Air Suspension and other issues
#21
I haven’t checked about leaking sound yet will do today.
is there anyway we can test the strut taking it out from car and inflating it out side using external compressor
#24
so you think is safe to buy the strut?
Is there anyway I can test the strut disconnecting from car to make sure it is the culprit and then buy one?
#25
You could take the strut out, remove the dust boot, connect a hose and air compressor to it, inflate the strut, and spray it all over with soapy water. This might show you where the leak is coming from.
#26
Thank you that helps will do it sometime and update the forum.
this really helps, just want to make sure before but a strut.
On the same issue , do you think control unit switch relay which is located next to where stud is connected to lover body may be playing role here?
i saw some vedios on YouTube which talks about a bad signal, do you think it is playing any role in my case?
i really appreciate and glad about the members of this forum for guiding to diagnose this complex problem.
#29
Finally I am at a state to remove my rear passenger strut. But I have difficulty , small black plastic assembly at the bottom of strut coming in my way to remove. Could some one guide me please?
#30
Never mind, I was able to get it out, I had to take another bolt off and level control arm and one more bolt to get it off.
Now I tried to inflate little by little and I see the strut takes pressure and boot inflate and immediately I feel the air leaving from the bottom of the boot. Looks like my strut is bad, I am going to order one fit it and let you guys know how it goes.
Thanks for all of you for kind help.
