Air suspension fault-any ideas?
I posted a while ago but these are the latest observations.
1.The yellow suspension light comes on after about 3 minutes of driving.(the outside temperature does not seem to affect it anymore, 3 minutes or so) )
2. The only thing grayed out after the light comes on is the Lift Mode.(regardless of the car speed)
3. I have not noticed the car to sag, even after leaving it overnight.(I measured it)
Should I continue to drive it until the fault becomes more obvious?
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 2A5D74F3857DFB4EE59-807F
3 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 114
Mileage: 113853 km
Time Indication: 0
Date: 2018.12.13
Time: 14:32:57
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 84
Mileage: 113864 km
Time Indication: 0
Date: 2018.12.13
Time: 14:55:08
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 12
Reset counter: 124
Mileage: 113876 km
Time Indication: 0
Date: 2018.12.13
Time: 19:46:35
Coding: 0015510
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 114
Mileage: 113853 km
Time Indication: 0
Date: 2018.12.13
Time: 14:32:57
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 84
Mileage: 113864 km
Time Indication: 0
Date: 2018.12.13
Time: 14:55:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 124
Mileage: 113876 km
Time Indication: 0
Date: 2018.12.13
Time: 19:46:35
Yellow light means the system is over inflated. 2-3 people fixed this by replacing the pump due to the pressure released valve was faulty inside the pump. Drive more until it's fully confirmed.
This is also one of VCDS falsely reported. Search and find the posts to confirm.
Cheers,
Louis
Cheers,
Louis
So rebuilding the compressor doesn't solve the issue since it's only piston rings.Correct?
Can the valve be replaced?
If I take it to the dealer I wonder if the their diagnosis equipment can possibly find more.
When my turn comes, I'll open the pump and check the valve solenoid. I bought the piston kit but never replace. It's a $21 waste sitting and collecting dust.
Knrauto
Q7 MK 1 Discussion
41
08-20-2021 07:21 AM
