Air Suspension lights on. VCDS Scan results included
UPDATE: I replaced the 40A fuse under the dash. I took the car for a 10 minute ride and so far no lights have returned. 🤞 I'd still welcome input on the other fault codes.
Hey guys. Both air suspension lights came on today. It's been nearly 3 years since I replaced the compressor and my theory is that the one I installed from Rebuild Master Tech has died. I'm in NC and I'm guessing that the 95 deg weather hasn't helped. A couple of days ago I thought I heard the compressor struggling for a moment, but never heard the issue after that one time. The vehicle hasn't sagged and is still at normal height which I would assume won't be for long.
I ran a VCDS scan and here are the results shortened to only the fault codes. Although I would like to focus on the air suspension I wouldn't mind input on the other items on the list. Keep in mind the dates on some of these as many happened a while ago.
Monday,08,July,2019,16:24:20:61930
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUML44E06N018741 License Plate:
Mileage: 215800km-134091mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E06N018741 Mileage: 215800km-134091miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F0783549
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E536E7AB9E6AF3F3B-807A
2 Faults Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 40
Reset counter: 255
Mileage: 207931 km
Time Indication: 0
Freeze Frame:
RPM: 623 /min
Load: 46.6 %
Speed: 5.0 km/h
Temperature: 93.0°C
Temperature: 28.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.716 V
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 112
Reset counter: 255
Mileage: 211336 km
Time Indication: 0
Freeze Frame:
RPM: 758 /min
Load: 67.4 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 69.0°C
Voltage: 11.303 V
Readiness: 0000 0000
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346HQ037505391
Coding: 0000003
Shop #: WSC 00000 000 00000
VCID: 326B7A0AADDE8BDF5F-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000011670
Subsystem 3 - Serial number: 0113.06.060000000100010096ÿ
Subsystem 4 - Serial number: 010096ÿ
1 Fault Found:
01319 - Control Module for Distance Control (J428)
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 105
Mileage: 185775 km
Time Indication: 0
Date: 2016.08.08
Time: 01:41:32
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 67916 260 51396
VCID: 285F98629B02F10FF1-807C
2 Faults Found:
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 59
Reset counter: 180
Mileage: 211118 km
Time Indication: 0
Date: 2018.11.21
Time: 16:34:01
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 215809 km
Time Indication: 0
Date: 2019.07.08
Time: 16:24:04
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601150033
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
3 Faults Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 147
Reset counter: 144
Mileage: 213033 km
Time Indication: 0
Date: 2019.05.03
Time: 09:06:07
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 213033 km
Time Indication: 0
Date: 2019.05.03
Time: 09:06:07
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 213033 km
Time Indication: 0
Date: 2019.05.03
Time: 09:06:07
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Shop #: WSC 02311 785 00200
VCID: 204F8042F332094FB9-8074
1 Fault Found:
02116 - Mirror Adjusting Motor
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 0
Reset counter: 162
Mileage: 215408 km
Time Indication: 0
Date: 2019.06.14
Time: 09:21:62
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 08902 444 56823
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 61
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02628 - Sensor for Swivel Module Position; Right
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 212936 km
Time Indication: 0
Date: 2019.04.29
Time: 18:47:18
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010248
Shop #: WSC 08316 444 57454
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1601140343
Coding: 344530393135313035412056413031363031313430333433
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 28
Reset counter: 255
Mileage: 205837 km
Time Indication: 0
Date: 2018.03.09
Time: 08:43:35
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 02:28:41
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 06:05:03
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 06:05:13
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 06:05:23
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000512200212
Shop #: WSC 12336 024 394758
VCID: 2D516976B4E0D42702-8078
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 5
Fault Frequency: 254
Reset counter: 144
Mileage: 185775 km
Time Indication: 0
Date: 2016.08.08
Time: 01:37:59
www.Ross-Tech.com
Coding: 0007773
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 40
Reset counter: 255
Mileage: 207931 km
Time Indication: 0
Freeze Frame:
RPM: 623 /min
Load: 46.6 %
Speed: 5.0 km/h
Temperature: 93.0°C
Temperature: 28.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 211336 km
Time Indication: 0
Freeze Frame:
RPM: 758 /min
Load: 67.4 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 69.0°C
Voltage: 11.303 V
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 105
Mileage: 185775 km
Time Indication: 0
Date: 2016.08.08
Time: 01:41:32
Coding: 0015510
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 59
Reset counter: 180
Mileage: 211118 km
Time Indication: 0
Date: 2018.11.21
Time: 16:34:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 215809 km
Time Indication: 0
Date: 2019.07.08
Time: 16:24:04
Coding: 0048702
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 213033 km
Time Indication: 0
Date: 2019.05.03
Time: 09:06:07
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 213033 km
Time Indication: 0
Date: 2019.05.03
Time: 09:06:07
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 213033 km
Time Indication: 0
Date: 2019.05.03
Time: 09:06:07
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 162
Mileage: 215408 km
Time Indication: 0
Date: 2019.06.14
Time: 09:21:62
Revision: --H03---
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 61
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 212936 km
Time Indication: 0
Date: 2019.04.29
Time: 18:47:18
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 28
Reset counter: 255
Mileage: 205837 km
Time Indication: 0
Date: 2018.03.09
Time: 08:43:35
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 02:28:41
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 06:05:03
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 06:05:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 207809 km
Time Indication: 0
Date: 2018.09.18
Time: 06:05:23
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Reset counter: 144
Mileage: 185775 km
Time Indication: 0
Date: 2016.08.08
Time: 01:37:59
I had the same headlight issue. I had to take out the light and since it was already dead, I used a multi vibrating tool and cut a square out of the bottom of the headlight. This was to repair the broken and frayed wiring to the sensor. I used heat shrink and liquid tape and some soldering to fix the wires. They all looked cracked from age and heat. To seal it back up I used a big hot glue gun and a combination of hot glue and super glue with an activator to seal it up. It works and you can't tell unless you remove the headlight. Its better than 1500$ from the dealer!
millatyme34
23
12-04-2015 08:54 PM
