Sponsored by:
Sponsored by:
Air suspension relay not engaging.
Old 10-14-2018, 04:08 PM
  #11
DML939's Avatar
Originally Posted by MP4.2+6.0
May vary by motor, but behind the driver's side wheel liner. On my W12 it is at the back side of the fender area, and you only see it if you pull away at least the rear of the fender liner.
As stated VCDS looking at various pressure readings may be possible, but I have not had to go there. You can/should of course check it for obvious air leaks w/ soapy water.
I'm guessing you don't have VCDS? But, may need to bite the bullet here. For example, you have no idea so far (without it) if there are trouble codes stored in the relevant control unit. First wrong guess on any part here will probably cost more money than it does. Alternately find someone/a mechanic with it to do the scan for you.
I have the obdeleven but I have not seen anything come up with the suspension in a scan
Old 10-14-2018, 05:32 PM
  #12
MP4.2+6.0's Avatar
Address 34. You'll see it in many of the inane full scans folks post at times. See Level Control Bleeding/Charging - Ross-Tech Wiki
An excerpt from one random scan I found from a quick search where the suspension had issues:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0019911
Shop #: WSC 11111 111 45799
VCID: 2809043BDEF51387197-807C
3 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 109
Reset counter: 209
Mileage: 252391 km
Time Indication: 0
Date: 2018.07.17
Time: 18:21:01
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 182
Mileage: 252495 km
Time Indication: 0
Date: 2018.07.19
Time: 13:20:16
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 191
Mileage: 252564 km
Time Indication: 0
Date: 2018.07.19
Time: 18:05:15
Old 10-16-2018, 04:55 AM
  #13
DML939's Avatar
Coding: 0019911
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 209
Mileage: 252391 km
Time Indication: 0
Date: 2018.07.17
Time: 18:21:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 182
Mileage: 252495 km
Time Indication: 0
Date: 2018.07.19
Time: 13:20:16
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 191
Mileage: 252564 km
Time Indication: 0
Date: 2018.07.19
Time: 18:05:15
So yesterday i pulled the wheel liner so i could see the pump and block and both look fine ( i am going to rebuild the compressor regardless). I have no leak tested as i need someone else to hold on the compressor while i look for bubbles etc. When i bought the car the guy did say his mechanic told him there was a leak in the passenger side front so i will need to address that. When i jacked the car up to get the wheel off and then turned on the pump, i got the rear end to raise back up to normal but the front did not move at all. I now only have the yellow suspension light on the dash and not the green. I checked the fault codes (obdeleven) and all i got for suspension was fault code 01399 which is self-leveling suspension compressor relay. Not sure if this is the relay under the dash i was manually activating or if its a different relay i need to check. I just cannot figure out why the relay does not activate on its own and i read everything i found on here in regards to suspension. Also im not sure why it seems like the front suspension isnt even getting any air. I know there is a leak but should it not try to lift up alittle especially on this side where there is no leak? Or is this a level sensor issue?
Old 10-16-2018, 07:50 AM
  #14
MP4.2+6.0's Avatar
There is only one suspension relay, so hopefully you found the right one. Search on it if you need pictures and are not 100% sure you have the correct relay. It was actually in two locations. Many like mine are under the dash as part of a relay panel and very close to where its 40A fuse is located. Some are under the top part of the carpeted area IIRC.
If you have a big leak, the front is not going to go up. The two sides are tied together by the sway bar anyway--which forces both sides down even when the car can pump up but then the air leaks from one side. I suppose you can try disconnecting sway bar temporarily to see if at least one front corner will then move up some. No one has ever tried to diagnose that way AFAIK, but it is logically just the reverse of trying to diagnose when both sides seem to come down at same time when only one side leaks. Just do it at one of the U shaped sway bar end links with the single bolts. From your description of a likely bad passenger side strut, try disconnecting on driver's side. No guaranties, but you might get some comfort if one side does come up in front.
And yes, look for broken or disconnected level sensors just in case. They are right there on the lower suspension arms in front. You should easily see them when looking at the sway bar ends. They rarely seem to fail. Most reports find them somehow mechanically unclipped or with broken arms--typically from repair mistakes or road hits/damage.
I can't separately comment on OBD eleven since I don't use it.
allroadSST
Audi allroad
33
05-25-2020 12:03 AM
DML939
9
10-11-2018 04:10 PM
Jose Antonio Escamilla Jr.
01-11-2018 03:20 PM
Chris Stinson
13
02-14-2015 10:54 AM
hsjb
12-20-2002 09:26 AM
Quick Reply: Air suspension relay not engaging.
