ami retro fit...how to split fiber optic cable ?
I need to install an AMI in an A6 and I have the fiber optic cable that requires taking a plug apart to change fiber cables. I did my install so long ago I do not remember what to do with the plug, and I can not find anything with search to show me. Anyone know how ?
You can't "split" the fiber cable. There is a Y adapter that comes with the kit, you install this between the changer and AMI module.
2 Attachment(s)
1 Attachment(s)
This may help also, same setup for doing the AMI:
Y adapter is the electrical side..
for the power takeoff from the CD changer. On the optical, you extend the loop by taking one side of the optical ring away from the CD changer, essentially moving it to the "same" side of the AMI unit, and then adding the optical between the two. The wiring kit did include a fitting for the optical that did seem kind of like a "splitter," but light wise I believe it's as I describe and that piece was actually probably a coupling to enable the extension and the in-out serial connection nature of the optical loop.
there is no 'y' adapter...
Originally Posted by bmwm750
(Post 24569613)
thats a start...
Originally Posted by mishar
(Post 24569614)
Will this help?
http://i155.photobucket.com/albums/s...psae375ebd.jpg http://i155.photobucket.com/albums/s...ps57bb3a04.jpg |
thats part of the puzzle
Originally Posted by 05SilverA8
(Post 24569617)
if you need detailed pictures of the connectors PM me and I will forward you some if you can't figure out how to get them apart.
1. Picture:
Release locking latch in fiber optic cable connector (arrow). 2. Picture: Release secondary latch (6) using a small screwdriver (arrow). Release catch (2) and remove fiber optic cable (5) with brass connector pin (4) from base module (1). |
