AMI Update
#11
Loving it, only drawback is gas mileage and miles per tanks (360 if I'm lucky). Back on topic though. Good luck
As far as I know there's no way to know what version is installed but updating can't hurt.
#16
I definitely wouldn't even try it. With how finicky the systems are I wouldn't. What is your reason for wanting to update your firmware in the first place? This thread refers to the AMI not the MMI for what it's worth.
#17
Its MMI software/firmware update. Reason for update is because the car had a MD changer when I bought it and I recently replaced it with AMI. Problem is that the MMI doesn't recognize the MMI when you go to source of music but when you go to the Hidden Menu, you can see the AMI specs there.
#18
Ah yes, your MMI firmware needs to be updated in order to recognize the AMI unit. I believe either 33.6 or the one revision before that is what enabled use of the MMI. As you don't know much on the topic and the MMI can be very finicky I'd just take it to a dealer and tell them to update the MMI for you. That or order the OEM original 46.1 firmware disc and upgrade it yourself. Connect a trickle charger in the event it takes a while.
#19
#20
What version is your MMI software?
Since you mentioned that you have a Japanese spec car, can you tell us what software version is currently running on your MMI?
