Anyone know the complete specs of this wheel?
AudiWorld Uber User
20" I understand. What is the rim width and offset as well as OEM tire size?
<img src="http://pictureposter.audiworld.com/33185/a8.jpg">
Thanks.
Thanks.
AudiWorld Uber User
I wonder if the offset would be a problem on an A6 4.2...
...same specs as the S6 and RS 6, (not the 2.7T, 2.8 and 3.0 before anyone says otherwise).
275 rubber might be a problem though. I know I can fit 265 under there. Currently running 255 but have a ET 30 offset.
Hmmmm?
Hmmmm?
The tires would be way too tall....
You would need to run a 255/30 - 20 (Conti Sport2, Pilot Sport2 or PS A/S). The offset should not be a problem as I have seen the 19's(et45) on an A6 2.7T (I know your's is a 4.2 but the suspension clearance should be the same). Just remember that they are 'spensive wheels so definitely be sure before you invest in them.
AudiWorld Uber User
I have adjustable coil overs....
Thanks again for your help.
I actually have more clearance then the 2.7T but because my fender "flair" are twice as wide as the regular body A6, I worry that the offset would not allow the wheels to stick out close enough to the end of the wider fender body.
Thats why I'm running OEM wheels off the RS 6 currently. Otherwise they would not stick out enough. With 265 rubber and 9.5 inch width of the A8 rim, this might compensate for the shortened offset though (?)
Ive seen the wheels you have in your sig on a GTI before so I know they will "fit" per say, but the offset is the only thing holding me back.
Hell yeah they are expensive, but there are deals about
Thanks again for all of your help on the subject.
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
Al_Bundy
09-02-2015 07:24 AM
