Audi A8 air suspension problem
I have a 2006 A8 L. The car was sitting in the driveway for a few days when it was cold. Somehow when I used the car on day I had the orange and green light on the dash board. Also the air bag light was on too.
I took it to the dealer and they said that the air compressor has a temperature sensor inside that failed. To fix that they need to replace "air compressor". To do that its about $2400 at the dealer. I was wondering if someone can give me hints or ideas what to do, if there is a cheaper fix. Also i noticed that some other guys have had the same or similar problems. I don't understand why this car is so sensitive to the weather. |
It is to monitor the operating temperature of the air compressor as a safety measure in case there is an air leak which causes the compressor to overheat.
I suspect you could probably pick up a replacement compressor on Ebay or similar or have yours repaired if you can do without the car while it is fixed? |
Originally Posted by tony1279
(Post 24101313)
I took it to the dealer and they said that the air compressor has a temperature sensor inside that failed. To fix that they need to replace "air compressor". To do that its about $2400 at the dealer. I was wondering if someone can give me hints or ideas what to do, if there is a cheaper fix. Also i noticed that some other guys have had the same or similar problems. I don't understand why this car is so sensitive to the weather. http://cgi.ebay.com/Compressor-Audi-...item5d2726d613 ???? + Find a good independent shop in your area that specializes in German autos and you should be able to save a ton. I don't have an A8 yet, but am hoping to buy one this year. Whatever the case, threads like these make me appreciate that coughing up $2500-$3500 for some sort of warranty on these vehicles is peanuts compared to expected repair costs. |
^ I just ordered one of those for my '04. Hoping it arrives this week. I'll post up once I've got it installed.
l8r) |
I asked around at other local shops specialized for German cars. They are expensive too, because the air compressor cost too much. These other shops charge about $1800, its less but still too much. I am willing to do it myself, but I don't know how hard it is. I am a handy guy but never worked in Audi before.
Hi!
Firs of all sorry about my bad english! Hope you understand! I have a weird problem with my A8 2003 - the suspension is too stiff! It is like riding on rims without tires. Sometimes it`s better-not so stiff, but lately it`s almost all the time stiff. And it`s the same with winter(245/45/18) and summer(235/50/18)tires. Anybody have the same problem? Have not done diagnostic yet, planing to do soon as possible... Aks |
where did you buy it
Originally Posted by akslionu
(Post 24104558)
Hi!
(Post 24104915)
Originally Posted by mishar
(Post 24104932)
Could be sucked in emergency running mode (limping mode).
It`s lifting and lowering almost all time normally, but sometimes lifting too slow and then I can hear the compressor doing little too much noise... Hard to say like that, I understand, have to wait for diagnostic probably and see what it shows. Let you know here if a problem is solved! |
