Audi A8 air suspension problem
Old 04-12-2019, 12:33 PM
  #151
Originally Posted by Mister Bally View Post
Please read the sticky at the top of the D3 thread. Follow what it says and you will find your answers.
To directly answer your questions:
Possible? Yes.
Y is it not going up? The sensor could be bad. That's why. Is it bad? I don't know. A wire going to it could be broken. The linkage between the sensor and the body/frame could be broken/missing. As the sticky says, you need vcds interface and software to test. Use standard troubleshooting techniques to visibly look for broken parts and wires. As far as which sensor, there are four. Vcds scan would tell you which one if a sensor is the problem.
This is what happened to me. I had a faulty sensor and 2 bad plugs that were filled with mud and corroded wiring. This also revealed a leaking strut. I replaced mine with a rebuilt ebay strut for 266$ US. You really need VCDS to check the measuring blocks of the sensors and to look at the trouble codes.
Good luck. It's not a bad system and is pretty logical. Complex but logical.
summitradio is offline
Old 04-12-2019, 12:52 PM
  #152
Thanks for the info Sumitradio,
I have read the Sticky and duly noted.
I am not the kind of person that would be comfortable carrying out any work on the car myself, not exactly my line of work.
i will get it into the dealer and onto the computer to see what is what.
From reading through the treads i suspect drivers side suspension is leaking (but i cant hear anything) or faulty compressor.
Reaches for the credit card and cringes.
gerryd is offline
Old 04-13-2019, 01:34 AM
  #153
Default suspension problems
Good morning folks,
So i have had a mechanic come out with his box of tricks, Plug it in to the car and the first error was that the suspension was leaking.
then a few minutes later a whole load more errors follow, suspension too low, compressor overheated and so on.
Now i need to get it to the garage, anybody any advice on how i can get the car raised back into a driving position or is this a recovery truck job?
Regards
Gerry
gerryd is offline
Old 04-14-2019, 08:02 AM
  #154
Jack88's Avatar
Originally Posted by gerryd View Post
Good morning folks,
Regards
Gerry
If it won't hold air, it won't stay up under any circumstance to drive it. Call a tow truck.
Jack88 is online now
ohsigmachi
03-29-2016 05:04 AM
Jan_PL_S6
Vehicles For Sale
12
11-27-2015 07:27 AM
DenverAudiQ7
Q7 Discussion
10-01-2015 07:38 PM
cclsvtf
Q7 Discussion
09-12-2015 01:06 PM
Quick Reply: Audi A8 air suspension problem
