Audi illuminated door sills project completed
#11
Hmm!
source,so having the front doors as a source would not illuminate the rear sill when only a rear door is opened. And the foot well light fixtures pop right out and were an easy source to solder into for power and ground because the inverter tucks away nicely above the footwell panel and the wires only have to be run about 8 inches from inverter to fixture. As opposed to running all the way through the door jam harnesss and fishing through the door etc, etc.
And,yes, this may be the only illuminated A8 sills in the US. If another forum member has them I hope they will chime in...I'd like to hear the story.
#12
The Dc to AC invertors make quite a bit of electrical noise. Just curious, when you open a door if you have the AM radio on, do you notice any noise or popping sounds?
I know, I know..... who listes to AM radio these days? I hardly do but every so often.... And yes, the doors are usually opened with the engine (and radio) off.
At the G2E show (Global Gaming Expo) going on in Las Vegas, there is always a vendor with EL ribbon panels that are used in casino signage. All different colors too.
#13
Aah!
#14
re: electrical noise...
As to AM interference, I just went out to the car and tuned to an AM station, then openened the door to trigger the sill...no intrerference.
#15
I just ordered the invertors, so when they arrive I will install.
any other tips ?
#16
Audi illuminated door sills project completedQuite awhile back I posted that I had bought a couple sets of illuminated door sills (normal wheelbase version) from Audi's Quattro GmbH German catalog. I have had them installed for sometime now, but only now got them functioning. With my point-and-shoot I was not able to take photos that have the various light sources balanced properly,but I have posted them anyway.
The problem I had was that Audi WAY over engineered these things. The instructions for installing them are 30 pages long !!
I manage to find these full set new.Would it bebissible you still have install manual to share
BR Marko
BR Marko
#17
There is no reason to do the install according to the manual as to the electrical part of things. The Audi method was WAY WAY more work than needed. I did one side their way....it was crazy, up under the dash, tying in to the CAN BUS system, etc etc.
All you need is to ty into the footwell lights because they come on when the door is open. I dont think you would even need to drill into the body under the sill area like Audi says to....I did so when I still thought I needed to follow instructions, but I think the wires could just have the sills sitting on top and come up and out of the kick panel to the foot well fixtures. These days I drive a W12, so I am making some illuminated sills with "W12" and that will be how I wire them into the car.
And remember: with EL technology you never want to energize the transformer without an EL strip connected or you will ruin the transformer.
Blip
Mid Atlantic Discussion
05-10-2005 04:16 PM
technokid
10-14-2004 05:16 PM
