Battery drain (suspect it's door handles)
Hi there,
I've got battery drain on my A8 (D3). It's draining about 0.5 volts overnight. I suspect it's the door handles. Anyone know if there's a way to find out for sure before I go to the trouble of removing door linings to disconnect it replace?
Thanks in advance,
Tom
Thanks in advance,
Tom
In my opinion, when a doorhandle fails it will keep the car from going to sleep.
so when your lights in the gear selector and the warning light knop stays lit, than the door handle is a possible suspect.
I have this issue too. Driver door handle. Intermittently will not be able to lock/unlock. Get codes for no communication with door handle. Just hasvent had time to open it up and dig in. May be loose connection, but suspect its door handle sensor problem
I believe there was a pot at one point saying you could swap just the sensor..
will that work? Or willt eh handle jsut 100% stop responding? Because sometimes I can't lock or unlock that door. the handle has no connection to the actual lock mechanism at times
That's a good question. It was a mechanic friend that suggested it might be an option. If anyone knows the answer would be great to hear.
