Sponsored by:
Sponsored by:
Battery replacement
Old 04-04-2019, 04:44 PM
Tbone6283's Avatar
Default Battery replacement
Hey guys , just few questions. Can I buy a Wal-Mart battery to replace the original one, seen a suggested H8 900 .ca. Seemed to work. Also can someone please direct me on the after install procedure as far as needing to clear codes or resetting this or that?? This car is pretty complex on everything when your just learning the layouts!! Lol. All is appreciated!!!
Old 04-06-2019, 09:24 PM
2015 A8L TDI
Dville's Avatar
This is what I did.
https://www.audiworld.com/forums/a8-...8-agm-2921236/
Old 04-07-2019, 08:38 AM
Brozee's Avatar
Yes, any battery that is of the same category can be used. Don't overthink it, pull out the old battery and install the new one. Remember to hookup the battery vent cable if you have one. If you have VCDS, you can code in the new battery; i didn't the last time I changed mine and there's no issues.
I'd personally go with this one and use a coupon code:
https://shop.advanceautoparts.com/p/...000%7CL3*15597
Old 04-07-2019, 11:22 AM
Tbone6283's Avatar
Big thanks!! To you guys. I grabbed an everstart maxxx h8 900cca at Wal-Mart 119$ with breather hose vent and it works like a charm. Found out the car will "learn" the fix autonomously in time. Good deal guys you guys are awesome!!!
TFT
20
03-09-2015 05:44 AM
jmartign
10-29-2012 05:44 AM
tilhas
A4 (B8 Platform) Discussion
13
11-30-2011 01:29 PM
Benallroad
Audi allroad
15
10-23-2008 06:12 AM
th1nk
10-03-2004 06:16 PM
Quick Reply: Battery replacement
