Camber Wear ??
Camber Wear ??
Passenger side back
negative camber? maybe? what else would be causing this
I looked around and didn't see any broken / hanging parts
Driver's side front? I had the same issue. Drove and steered fine, even had a 4-wheel alignment done 8 months prior. Tires maybe had about 10K on them. Changed out upper control arms, ran winter wheels with no noticeable wear on those tires.
I would also guess control arm bushing causing your alignment to be way out. Only a guess but it does not look like negative camber since it's only on the very edge.
