Sponsored by:
Sponsored by:
CEL on (Linear Oxygen (Lambda) Sensor B2 S1)
Old 04-02-2014, 04:49 AM
  #11
nathanwind's Avatar
Originally Posted by werd
Did you ever find a solution?
So strangely, after I did my oil change (which included disconnecting the airbox/etc) I also unplugged the pigtail for the sensors as described, cleared any lingering codes, and my CEL has been gone for some 2000+ miles. So essentially so far so good, and *thankfully* I didn't/haven't had to replace the O2 sensor (knock on wood).
Old 04-04-2014, 02:35 AM
  #12
werd's Avatar
I have been having intermittent O2 faults with B2 S1 being the majority of them. I disconnected the connectors and applied electrically conductive grease. Currently waiting for them to reoccur. 2006 A8 @ 180K.
Old 04-04-2014, 04:58 AM
  #13
nathanwind's Avatar
Please keep me/us posted...though my '06 A8 had 79K on it when this happened back in November, as mentioned it's been over 2000 miles and 4+ months and so far so good.
Old 08-17-2014, 10:02 AM
  #14
werd's Avatar
Ok...... Been a while and still fighting B1 and B2 S1. After receiving multiple miss fires, I did more digging. Currently replacing the injector O-rings that seal the intake manifold. Looks as though this may have been the problem. Will report back...............
Old 04-01-2017, 05:45 AM
  #15
ebi718's Avatar
So, a quick search brought this up. No CEL yet but last weekend the D3 was acting up (engine fluttered after cranking/starting), a VCDS scan returned these errors for Bank 1 Sensor 1.
Code:
008785 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
               P2251 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 139262 km
                    Time Indication: 0
                    Date: 2017.03.05
                    Time: 15:08:51
000304 - Oxygen (Lambda) Sensor B1 S1
               P0130 - 001 - Malfunction in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 139214 km
                    Time Indication: 0
                    Date: 2017.02.20
                    Time: 17:45:12
By the way, this was 30 mins after I left my local Audi service dept for yearly emissions/ inspection sticker - how fortuitous?! After making it back to the shop, the Tech said he cleared the codes and that I would be replacing all 4 O2 sensors and maybe the HPF pump; SA quoted ~2200+. (I didn't bother to ask if they don't normally scan a vehicle during inspection.)
Haven't driven it much since, but I will be checking the colored connector (front passenger side) today; hopefully unplugging/plugging it back in and clearing codes might suffice.
Old 04-01-2017, 09:58 AM
  #16
MP4.2+6.0's Avatar
Code:
All 4 sensors when only one codes for both errors? Service biz must have been pretty slow that day and/or the end of the month + quarter quota stats came out from management...
You should be looking at the (USA) passenger side forward sensor. Sure, try the connector first. After that, replace sensor since it is clear there is an electrical problem there. And if still no joy, then suspect car side connector terminals and related wiring close in to connector area.
Old 04-11-2019, 03:31 PM
  #17
jmayfield23's Avatar
So where are the connectors that connect the o2 Sensor directly?
originaliowan
10-24-2019 07:24 AM
Blue2000S4
03-24-2010 08:52 AM
valentine1
11-13-2009 06:09 AM
audiquattroduo
11
11-13-2008 02:46 AM
WaggsA6
10-26-2006 08:16 PM
Quick Reply: CEL on (Linear Oxygen (Lambda) Sensor B2 S1)
