Center differential being replaced....finally
#21
AudiWorld Wiseguy
Torsen diffs are very effective and work very well in the right application, such as in a road car where a true mechanical full time AWD system is needed, rather than the more usual electronically controlled clutch based systems. But mess with its TBR and they become pretty ineffective.
#23
AudiWorld Wiseguy
If you don’t like it, only apply the lightest of gas when turning full lock, or whilst coasting only. Hey presto, no “grumble”!
#26
Ron did you resolve the thumping under the back seat at 300,000 miles or is that kms when you posted about it in 2021?
Is the diff central hanger bearing support still intact?
How about the other wear items, like rubber support mounts for the drive train?
Audi are very clear about not adding friction modifier to a Torsen unless it is rebuilt and starting with completely clean metal gears without the friction modifier on the surface.
Acceler8
06-19-2005 12:35 PM
NIEMALS FOLGEN S4
11
05-13-2005 07:46 AM
Inquisitor
05-04-2005 03:25 PM
