Clogged sunroof drains totaled my car!
#31
Somebody needs to make sunroof maintenance and protection kit!
This is too catastrophic.
Rains like heck over here too in the PacNW. Roof drains have been an issue for me in lots of cars: the various Porsches that came through, VW Beetle, etc. Lots of gunk to clog things up. I've using compressed air and steel wire.
Depends on the water quality for damage. Pure water will not conduct and nor will it do much damage corrosion-wise. Best thing to do is pull disconnect the battery and start a drying process.
If it flooded the harness, well long term issues, chasing electrical faults. Total the car just to avoid future problems - a shame but I can see the reasoning. Labour $$.
Now for the ultimate sunroof-clogged flooded monster check out this one. It was nasty
#32
Now for the ultimate sunroof-clogged flooded monster check out this one. It was nasty https://twitter.com/Garage9_com/stat...32403741134849
#33
Replacing sunroof and roof lining also going to finally get it tinted
Thinking my sunroof has never leaked but I will check all the drains while I am at it.
All four blocked!!
Got the dewalt vag and duct taped to the hoses one by one and vacuumed till they were partly unblocked then taped the hose to it on low.
Cleaned them all.
Front left was already full of water before I started.
Front right leaks somewhere down the windscreen pillar.
I might put a silicone plug semi temporary permanent in it for the time being until I decide if it is plausible (possible) to fix it.
Best thing to slide inside the hoses would be the hose they use on fridges and water coolers.
It's about 5mm flexible but rigid enough to push through.
Only had about a meter of it and was not long enough.
I don't think the sunroofs leak much when closed.
So if you have not checked your drain hoses you may be in for a shock one day.
All four blocked!!
Cleaned them all.
#35
I was skeptical too, and being that I'm the actual insurance agent who insures the car, I had close ties to the adjuster, who I made certain was on his game when it came to settling the claim and making certain we weren't being taken. I physically inspected the car at the dealer (which I also insure) and could see the water damage in both fuse panels on either side of the car. It was a mess. I absolutely LOVED that car and pleaded with the adjuster not to total it. It's not easy finding one with all the options I had, including B&O sound.
I've looked for other A8's/A8L's from 2007 to 2009, but haven't found one with the B&O sound in it, unfortunately. I got a little spoiled by that!
musantemike
12
06-20-2008 02:29 PM
