The Codes are back!
The Codes are back!
Okay, so the dreaded codes have returned, only about 200 miles since the throttle body and PCV were replaced. Thought all was good considering 200 miles was the farthest I've gone without codes since I bought the car three years ago. I am at a lost at this point. Any and all suggestions are greatly appreciated.
So here is what has been done so far:
New Throttle body (me)
New PCV (me)
New Spark Plugs (me)
New Oil (me)
New Oil filter (me)
New Air filter (noticed the hose on the bottom of air filter housing will not secure properly)
New B1 S1 sensor (by Audi)
New B2 S1 sensor (me)
ABS control module (by Audi)
Plenum cleaning (me)
Vehicle : /scan/VAG/
Test-Path: Audi, Systems, Control Unit, Common, 01-Engine, Read Codes
Read Codes
17950 Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal: P1542 - sporadic 008-Implausible Signal
18061 Please check DTC Memory of ABS Controller: P1653 - sporadic 008-Implausible Signal
19058 Linear Oxygen Sensor B1 S1 Pump Current Trim Circuit Open: P2626 - sporadic 004-No
Signal/Communication
Test-Path: Audi, Systems, Control Unit, Common, 01-Engine, Freeze Frame Data
Freeze Frame Data
17950 17950
Fault Status 11101000
Fault Priority 0
Fault Frequency 2
Mileage 173824 km
Time Indication 0
RPM 1405 /min
Load 72.1 %
Speed 17.0 km/h
Temperature 80 °C
Temperature 21 °C
Absolute pressure 0.00 mbar
Voltage 14.351 V
Timing angle 67.9 °BTDC
18061 18061
Fault Status 01101000
Fault Priority 0
Fault Frequency 3
Mileage 173824 km
Time Indication 0
RPM 1298 /min
Load 48.6 %
Speed 17.0 km/h
Temperature 80 °C
Temperature 21 °C
Voltage 14.478 V
Timing angle 9.8 °ATDC
19058 19058
Fault Status 01100100
Fault Priority 0
Fault Frequency 1
Mileage 173833 km
Time Indication 0
RPM 1868 /min
Load 15.3 %
Speed 104.0 km/h
Temperature 81 °C
Temperature 15 °C
Voltage 14.351 V
Timing angle 9.6 °BTDC
DTC that caused required freeze frame data storage P0121
Fuel system 1 status CL
Fuel System 2 status CL
Calculated Load Value 72.2 %
Engine Coolant Temperature 176 °F
Short Term Fuel Trim -Bank 1 -4.7 %
Long Term Fuel Trim - Bank 1 0.0 %
Short Term Fuel Trim -Bank 2 -4.7 %
Long Term Fuel Trim - Bank 2 0.0 %
Engine RPM 1405 rpm
Vehicle Speed Sensor 11 mph
Ignition Timing Advance for #1 Cylinder -5.5 ° Intake Air Temperature 70 °F
Air Flow Rate from Mass Air Flow Sensor 0.02 lb/s
Absolute Throttle Position 11.0 %
Commanded Secondary Air Status OFF
New PCV (me)
New Oil (me)
New Oil filter (me)
Read Codes
Freeze Frame Data
17950 17950
Fault Priority 0
Fault Frequency 2
Mileage 173824 km
Time Indication 0
RPM 1405 /min
Load 72.1 %
Speed 17.0 km/h
Temperature 80 °C
Temperature 21 °C
Voltage 14.351 V
18061 18061
Fault Priority 0
Fault Frequency 3
Mileage 173824 km
Time Indication 0
RPM 1298 /min
Load 48.6 %
Speed 17.0 km/h
Temperature 80 °C
Temperature 21 °C
Voltage 14.478 V
19058 19058
Fault Priority 0
Fault Frequency 1
Mileage 173833 km
Time Indication 0
RPM 1868 /min
Load 15.3 %
Speed 104.0 km/h
Temperature 81 °C
Temperature 15 °C
Voltage 14.351 V
Engine RPM 1405 rpm
I’ve also been noticing an erratic fuel gauge every time I start the vehicle and while driving. For instance, I would be at 3/4 (325 mi til empty) of fuel. While driving a short 5 miles or so it will drop to less than 3/4 (290 mi til empty). Could this be the fuel pumps going out. And could that cause the other three fault codes I get?
So, the gauge is reading fine, but the calculations for fuel economy are off? From what I recall, it uses a sort of baseline to start with what it thinks you can do, and as you drive, it adjusts based off of your driving style. It also seems the baseline favors freeway travel, as if it expects you to go on a road trip.
Well, if the only symptom is your fuel economy calculations, that itself sounds normal. Is your actual fuel economy any different than normal, as calculated tank to tank?
Did a fuel level adaptation reset. Seems to be working fine now. Except the fuel economy is sucking. Bad. There is something seriously wrong with the fuel consumption. So I went back through again searching for air vac leakage. Nothing. Should I try checking something else?
Did not change the fuel filter yet. List of what was change in initial thread. The codes I keep getting are sporadic. I get the usual codes mention in this original thread. Then I get the occasional O2 sensor trouble code. B2S1 then B1S1, never at the same time. The engine begins to idle roughly after clearing the codes and driving about 20 to 50 miles. At initial start up the engine rpm shoots up erratically and does not go back down to normal until I clear the codes again. Just to drive another est 20mi. then it does it again. This coupled with a full tank of fuel on Monday, drive a little over 30 miles by Wednesday and be at half a tank. But this only happens when the codes pop up. When the codes don’t show, the car idle and drives perfectly fine.
lrrr
12-01-2006 06:33 PM
GettinAudiHere
05-22-2006 01:09 PM
Milpitas2.7T
19
11-30-2005 11:08 PM
