coming home' function stopped functioning
Old Mar 17, 2010 | 07:09 PM
awdinut's Avatar
Default coming home' function stopped functioning
any one else ever experience this? Is it a VAG Com fix ?
Old Mar 18, 2010 | 02:48 PM
gaspasser19's Avatar
I'm not familiar with the coming home function.
Old Mar 18, 2010 | 02:56 PM
parkrog2's Avatar
Several times over the years mine either stopped or didn't come on at start, just use reboot sequence to reset. Look in book press 3 buttons at same time to reboot.
Old Mar 18, 2010 | 05:24 PM
awdinut's Avatar
Default MMI reboot did not restore 'coming home'
I'll try the VAG COM.
Old Mar 19, 2010 | 06:18 AM
Jay Franq's Avatar
What is "coming home" feature? Never heard of this.
Old Mar 19, 2010 | 09:42 AM
MP4.2+6.0's Avatar
Tech Guru
Default a.k.a. delayed exit lighting
kicks on the lighting around the car when you shut off ignition at night (like what goes on when you click the remote), and then turns it off on a delay of 10-60 seconds of locking car.
One downside is it is hard to be sure you turned your lights off if you use the manual switch.
Old Mar 19, 2010 | 09:44 AM
MP4.2+6.0's Avatar
Tech Guru
Default Haven't seen or heard of issues here...
yes, scan it for codes. Probably a variety of components that make it function.
Old Mar 19, 2010 | 01:51 PM
Mister Bally's Avatar
The chime should make noise when you open the door if the headlight switch is in anything other than auto or off. Just like leaving a key in the ignition switch.
Then again, my 2001 Beetle's system does not work. Unfortunately, the door switch is integrated into the lock latch. Read $$.
Old Mar 19, 2010 | 03:03 PM
MP4.2+6.0's Avatar
Tech Guru
Default Yeah but...
I find the chime pretty worthless in the car from experience. You are right that is what it does. But, the radio is on until the point the door is opened, so that makes it more complicated to listen for it, and that is after the usual parking sensor tone symphony that has me starting to pay less attention to other tones and chimes. I find looking at the instruments is best. Panel is dark if lights off but coming home has kicked in, while it stays illuminated w/ lights on of course.
kevrhof
A6 (C7 Platform) Discussion
Mar 4, 2017 10:58 AM
Edge
Q7 MK 1 Discussion
Dec 29, 2009 01:24 AM
MarkItZero
Q7 MK 1 Discussion
Mar 10, 2007 11:46 PM
bubbalito
A4 (B7 Platform) Discussion
Nov 12, 2005 10:35 AM
