Cost to replace starter and Valve covers?!
I'm having problems with my starter. Once about every 15-20 times it randomly doesn't start at all. I have to take the key out lock and unlock the car a few times and then try a gain and it works. My tech ran a bunch of test and he says everything points to the starter. So I'm getting that replaced he's quoting me $1470 to replace the starter. I also have a small leak in the valve covers the quote for that is $2300. Is it just me or does this seem like a lot ?
TIA
TIA
I think Mister Bally has done the starter, so see if he checks in.
Valve covers sound like way, way too much. Gasket set in OES quality can be had for $30 per side: https://www.autohausaz.com/catalog/c/audi/2004/1422188-a8_quattro_l/20-engine_parts_seals_gaskets/5500-valve_cover_gasket_set?s=d&page=1 From doing it on my 2000 A6 4.2, I would say a few hours per side. It is cost effective to do spark plugs and air filter at same time given stuff you are removing all the way down to the plug coil packs. At $2300, those must be gold leaf lined gaskets supporting a 10 hour $200 labor rate ride. S8's can be no fun, and W12's maybe a runner up, but even there it would seem high. Fleece me...
Uh...
The valve cover gaskets are $30 and 2 hours labor, so that quote is just crazy.
http://audipages.com/Tech_Articles/e...%20rev%200.pdf
TIA
TIA
Same thing with me on the starter . 08 FSI. I just hit the stop button, then start, and it starts right up. It'll crank just fine just something isn't getting a signal. Happens once every few months.
Valve covers....easy DIY. It'll take you a few hours. Remove air box and connectors, get a low profile socket wrench for the rear bits and it'll be easy going. Mine all came out with ease after 144k miles. No idea where your guy came up with those numbers. But I'm sure he will buy a round of drinks for everyone at the bar if you do that.
GearWrench 85035 35 Pc MicroDriver Set https://www.amazon.com/dp/B0062FSAVI?ref=yo_pop_ma_swf
If the starter ever fails to crank twice; the starter is going bad. VCDS diagnostics will confirm it. But, it is a standard troubleshooting technique. There is a software glitch that causes mine to not crank maybe once every 200 attempts. It used to be one in 25 or so years ago but somehow healed itself.....
Subframe has to come down to replace the starter so a tough job. This is one I actually paid a good, Independent shop to do as the labor was less than the part. OES (Valeo?) gear reduction starter was about $400.00 and labor was three hours at $110.00
Remember Homeslice, you're in LA. The labor rate is probably approaching $200 at Audi dealers and $180 at indy shops. Only way to save is by buying an OES starter instead of genuine Audi.
Others have commented about the valve cover gaskets. It took me about three hours to do one side on my '04. I was tired because I was replacing the front end of the car, but that's another story....
Common problem on these cars, no one could really find the culprit. Just deal with it. Mine has done it since i bought it in 2008... Same exact situation, Just recycle ignition and you're good to go. I don't need to unlock the car though.. I use push to start every time, if this happens I hit stop or engine off, and then push to start again and it starts right up. I believe it's the ignition lock or security not syncing properly and therefore stopping the car from turning over electronically.
