Courtesy Step bulb Swap to LED (under the Door jam)
15 Attachment(s)
So i ordered some LED's from autoillumination.com because I was getting real tired of the DULL halogen look..
This is purely cosmetic. Bulb size is 168 or 194 both the same.. Pretty simple swap a Flat head screwdriver is all you need.. Here we see the difference in LED's (left) Bulbs (right) Attachment 87319 Again in a different angle. Attachment 87320 Here we see how the housing looks already popped out, Simple procedure just place the Flat head towards one of the edges an pop it out (there should be a small slot where the flathead fits right in), PLAIN an SIMPLE! Attachment 87321 Attachment 87322 There is a cover towards the inside of the housing to dissipate heat, again the flat head towards one of the TABS and it comes off. Attachment 87323 Here the look of the halogen BULB DULL isn't it! CAREFUL CAUSE THESE BULBS get hot QUICK! PULL them out an replace with the LED... Attachment 87324 Attachment 87325 EWW looks old.. Attachment 87326 Here is what the LED looks like, NICE isn't it.. BRIGHTER! Attachment 87327 Attachment 87328 Look at that output, bright an not dull.. Attachment 87329 Attachment 87330 Attachment 87331 Attachment 87332 My next Project, LED's in the DRL no Error marking LED's Stay tuned.. Attachment 87333 |
I know what I'm doing next Sunday! Thanks for the pics
Very well done tutorial! I had to go out immediately and check out the feasibility. I got all the way to the bulb in just a few minutes. I'm with transporter2004. I'll be plopped on my garage floor inserting LED's next weekend. For now I need to get the bulbs. Thanks so much for sharing AEinaD3! It's posts like this one that make a site like this excel! ;)
Thanks for the post AEinaD3. Nice! Can you give the part number from autoillumination.com as they just list a lot of LED supplier links. Did you actually purchase the LED from e-bay or superbrightleds.com or ?
Thanks. |
Originally Posted by perlfather
(Post 23984406)
Thanks. They are #8 from the top of the page. The LED's i got are under the SIZE# 194. http://autolumination.com/194.htm An their description: High Powered 5050 3 Chip SMT Leds - Outfitted with Canbus Bulb-Out Warning Cancellation Chip Designed to eliminate most electronic bulb-out warnings in BMW, Mercedes, AUDI, VW, Volvo, and most others. |
Originally Posted by AEinaD3
(Post 23984471)
Thnx guys Pictures speak 1,000 words..
They are #8 from the top of the page. The LED's i got are under the SIZE# 194. http://autolumination.com/194.htm An their description: High Powered 5050 3 Chip SMT Leds - Outfitted with Canbus Bulb-Out Warning Cancellation Chip . |
(Post 23984547)
Thanks again. It looks like you purchased the 4 LED version. Correct?
Just finished installing my driver/passenger lights. Very easy to do. I just used a letter opener to pop the covers off, then used the tip of the opener to pop out the small halogen bulb. Instantly working, very bright and much better looking. Not a single error thrown once.
<img src="http://i52.tinypic.com/2r6f6hh.jpg" border="0" alt="Image and video hosting by TinyPic"> <img src="http://i51.tinypic.com/2hd8pbm.jpg" border="0" alt="Image and video hosting by TinyPic"> |
(Post 23983613)
This is purely cosmetic. Bulb size is 168 or 194 both the same.. Pretty simple swap a Flat head screwdriver is all you need.. williebone |
LED City lights
(Post 23984673)
YES 4 LED version..
https://www.audiworld.com/forums/sho....php?t=2788968 How about the fog lights? Can I use PED as well? Thank you, A. |
