Crazy Louie's E-Z MMI Interface (AKA What I Want for Christmas)
#41
Your plan B is quite simple...
Thanks for the info. I would have never thought about it being differentiated by what device the cable is enabling, logic was that the differing AMI systems were the salient issue. I would have been looking for a 'C' suffix AUX cord and never found one probably. Seems like the two BT dongles should acheive the objective, of course I will have to rig the set up each time I want to use the RSE, but that is not often. And doing the occasional plugging-in of the dongles seems preferable to me that installing the TV tuner, doing the MMI R&R, etc.....all that stuff I dont understand makes me kinda dizzy.
If the dongles dont get it done, then I will get back to you for the details of plan 'B'.
Here is your plan B.
Get yourself a 6-10ft Auxiliary extension cable, run it from the audio out of your screen to your AMI auxiliary cable... all done.
Cheers,
Louis
#42
I forgot, Audinut, you can test to see if you have to go to plan B or not. Take your bluetooth transmit - connect the input to your Phone headphone jack, connect bluetooth receive aux out to your PC desktop speakers input jack, play music on your phone, if it comes out at the speakers - you don't need plan B. If it doesn't, plan B is a must.
Cheers,
Louis
Cheers,
Louis
#43
Ok, Atomic,
The parts for FBAS are here, when do you want to do it? Turn your HU to "A"?
If you're not going to use the video, then you can do it later. When the TV tuner gets here, I'll send it with the cables, the Bluetooth to get your music streaming going.
#44
here's what I currently do...
Cheers,
Louis
Cheers,
Louis
#46
Everything is slowly but surely here... But
Atomic has more things to worry about than the Bluetooth Streaming stuff. I''ll test and make sure everything works and put them away until he's ready. Today the TV Tuner came, I'll check this weekend to make sure it works.
Barsarab, If you want the cables, give me your address - I'll test the cables with this TV tuner and send it to you next week.
TV Tuner 4E0-919-146
The rear connectors - all look OK.
Cheers,
Louis
Cheers,
Louis
#48
Success !!
And the receiver works even with the glove box door closed; so all and all a very easy and tidy solution to the sound problem.
Thanks again for the info about the AUX cord compatibility.
#49
The second BT transmitter/receiver came today and I plugged it into the AMI AUX cable and paired with an identical unit plugged into RSE headphone jack I got totally in-sync video sound over the car's Bose system. Two of these are what I used......https://www.ebay.com/itm/Brightech-B...8df7:g:h5kAAOS
Very smart solution.
Cheers,
Louis
#50
There is a switch to set for transmit or receive, then hold down the on/off buttons till they go into pair mode. They have a light to indicate they have paired, and that all there is to it....BT with no discernible delay.
