D3 A8L Suspension Problems
2007 Audi A8L Issues:
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: --H16--- Serial number: AUX3Z0F4794778
Coding: 01060009190F0120
Shop #: WSC 05927 444 87830
VCID: 20483BC2F358A341C9-8074
4 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 285823E29B685B0181-807C
2 Faults Found:
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Coding: 0015510
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
4 Faults Found:
P1602 - 002 - Voltage too Low - Intermittent This says voltage is too low. Increase it.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller This says to check DTC Memory of ABS Controller: Check it.
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Coding: 0015510
2 Faults Found:
01575 - Control Switched Off This says control switched off. Maybe try to switch it on?
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
009 - Open or Short to Ground This says there's an open or short to ground. Resolve it.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Coding: 0015510
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
Instead, Please read the first post in the sticky ( the one with PLEASE READ THIS ) at the top of the D3 thread and follow it. In particular, the part about searching for prior threads and posts. The air suspension is brought up in it as well.
Help us help you but more important, you will learn how to help yourself.
stroker351w
12-05-2014 04:25 AM
dihanie
VAG-COM Discussion
10-06-2008 11:54 PM
