D3 w/ ECU Malfunction. Help Deciphering the Scan results.
I have been digging through multiple forums and I haven't been able to find any definitive answers. Hoping someone from this site can help. I have a 2008 Audi A8L (D3). The issue started with the TPMS light coming on, then i got the "Parking Break Malfunction" light. I also notice the steering got tight as if the power steering was out. As I drove down the highway I notice the doors unlocking and locking by themselves. Then the info screen on the instrument cluster went from a red "blank" screen to black then back to normal. The radio cut out as well as the A/C. This went on of a mile or so then everything went back to normal with the exception of the TPMS light and the Parking break. I was able to make it home and ran an auto scan. It seems from what I am reading on other sites there is either a CAM communication issue or the ECU is dieing or has died. Im hoping some one that is a little more seasoned with reading these scans can give me an idea of what's going on.
Scan Results Below:
VCDS Version: Release 12.12.0
Data version: 20130910
Wednesday,05,July,2017,18:50:20:62939
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV94E28N016788 Mileage: 155300km/96498miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Sporadic communication error 1000
67-Voice Control -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 560 D HW: 4E1 907 560
Component: 4.2l V8/4V 0020
Revision: 71H22--- Serial number: AUX3Z0H3748064
Coding: 01060009190F0120
Shop #: WSC 02313 785 00200
VCID: 23450907E2202306A91-8076
8 Faults Found:
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent - MIL ON
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent - MIL ON
049682 - Steering Column Control Module
U0212 - 008 - No Communications - Intermittent
049425 - No Communication with Battery Energy Control Module
U0111 - 008 - - Intermittent
053250 - Please Check Fault Codes in Comfort System Control Module (J393)
U1002 - 008 -
049473 - Body Control Module (Central Electric 2)
U0141 - 008 - No Communications - Intermittent
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 BQ
Component: ESP 5.7 allrad H49 0540
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2A5BE423850AF24EEA7-807F
No fault code found.
Address 05: Acc/Start Auth.
Cannot be reached
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348DX087528732
Coding: 0000003
VCID: 224B0C03FD3A2A0EA27-8077
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000063254
Subsystem 3 - Serial number: 0110.04.080000000100010033ÿ
Subsystem 4 - Serial number: 010033ÿ
10 Faults Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
01964 - Control Module for Seat & Steering Column Memory (J136)
01320 - Control Module for Climatronic (J255)
01308 - Control Module for Roof Electronics (J528)
00457 - Control Module for Network (J519)
01330 - Central Control Module for Central Convenience (J393)
02873 - Control Module for Back-Up Camera (J772)
02103 - Control Module 2 for Vehicle Electrical System (J520)
004 - No Signal/Communication - Intermittent
00474 - Control Module for Immobilizer
02095 - Component Protection Active
000 - - - Intermittent
Address 08: Auto HVAC Labels: None
VCID: 55A167DFBCF48DB6975
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 275D1D175618CF26F59-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7H0313168
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV0002L6W
Coding: 0532707
VCID: 29591B2F800CF956E3D-807C
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 02QHX
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB403B01A89Kÿ†63
Subsystem 5 - Serial number: 01A89Kÿ†63428RB403B01A62Cÿ†63
Subsystem 6 - Serial number: 01A62Cÿ†63528RB403B01A67Iÿ†63
Subsystem 7 - Serial number: 01A67Iÿ†63628RB403AFFCE18ÿ†63
Subsystem 8 - Serial number: FFCE18ÿ†63729RB403B2918ARÿ†63
Subsystem 9 - Serial number: 2918ARÿ†63829RB403B2915ETÿ
Subsystem 10 - Serial number: 2915ETÿ
2 Faults Found:
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 K HW: 4E0 920 951 K
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H3100200
Coding: 0048283
Shop #: WSC 44442 001 1048576
VCID: 2D51EF3FB4E4E5760F5-8078
2 Faults Found:
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0840902AA
Coding: F5D5DF7F707A0E00
8 Faults Found:
02230 - Digital Radio (DAB) (R147)
01325 - Control Module for Tire Pressure Monitoring (J502)
00470 - Combination comfort Databus in Single Wire
007 - Short to Ground - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
01332 - Door Control Module; Passenger Side (J387)
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046007 Serial number: AUZ5ZBH8373003
VCID: 183F2EEB2B6670DE4C3-804D
1 Fault Found:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B55E1278AF0EB46111-807E
1 Fault Found:
00456 - Control Module for Access and Start Control (J518)
Address 36: Seat Mem. Drvr
Cannot be reached
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H51 0990
Revision: 00000000 Serial number: 395D.087512984
Shop #: WSC 08167 444 82862
VCID: 3169F34FA8DC81962BD-8064
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. Labels: None
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000012198
Coding: 0000026
VCID: 2C57E23B8FFEEC7E18B-8079
3 Faults Found:
000 - -
Address 4F: Centr. Electr. II
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 02301 444 52373
VCID: 204F060BF336381EB43-8075
2 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - MIL ON
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000018
VCID: E9D9DB2FC08CB956A3D-80BC
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 65: Tire Pressure Labels: None
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000804080035
Shop #: WSC 12336 024 394758
VCID: 3467FA5B57CEB4BE40B-8061
2 Faults Found:
000 - -
Address 6C: Back-up Cam.
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005029848
Coding: 0010900
VCID: 2541171FEC14DD36C75-8070
End ---------------------------------------------------------------------
Scan Results Below:
8 Faults Found:
000771 - Cylinder 3
U1002 - 008 -
Cannot be reached
Coding: 0007597
Cannot be reached
Cannot be reached
Coding: 0000003
10 Faults Found:
Cannot be reached
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Coding: 0532707
2 Faults Found:
Cannot be reached
Coding: 0048283
2 Faults Found:
8 Faults Found:
1 Fault Found:
Coding: 0015510
1 Fault Found:
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000026
3 Faults Found:
000 - -
Cannot be reached
Cannot be reached
Revision: --H03---
Coding: 0000532
2 Faults Found:
00576 - Terminal 15
Coding: 0000018
4 Faults Found:
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
2 Faults Found:
000 - -
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0010900
Some of your codes look unrelated to comms. though; clear as many codes as you can, run the car again and then see what's left with another Autoscan.
Julian
BTW1 - that's an old version of VCDS
BTW2 - you're not running the latest/last MMI version for the US - 4610
How old is the battery? If any signs it is fading or if by chance still the original, I would replace. If battery is newer and seems good, try disconnecting for 30-60 minutes. Then clear all codes module by module (not the clear all supposed choice, which often doesn't work) and rescan.
Big picture, D3's can get flaky electrically when battery is headed south. Sometimes the old fashioned disconnect can relieve electrical indigestion they seem to sort of get, maybe also tied to failing battery. After that, scan can be looked at again--too much "noise" now.
I tried disconnecting the battery for about an hour, cleared all of the codes that would clear and re-scanned. This second scan did look a little better but there are still a few moduals there are not communicating. (See scan results below)
I checked the voltage at the battery and it as 11.7v Could these issues be caused by a failing alternator??
Friday,07,July,2017,12:04:04:62939
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
4 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:28:05
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0°C
Temperature: 30.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.430 V
P0300 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:29:30
Freeze Frame:
RPM: 880 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:29:30
Freeze Frame:
RPM: 880 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:29:30
Freeze Frame:
RPM: 880 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 30.0°C
Voltage: 13.843 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4443773
Coding: 0000002
Coding: 0007597
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H3748064
Coding: 0410624
Shop #: WSC 02391 785 00200
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 2040
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 24470A1BE72E243ED0B-8071
Coding: 0000003
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000147245
Coding: 0037185
VCID: 1C3732FBDF5E1CFE68B-8049
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO10042008065A000000000220ÿ†89
Subsystem 5 - Serial number: 000220ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO09042008065A00000000
Subsystem 7 - Serial number: 65A000000000006ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143123
VCID: 387FCE6B4BA650DE6C3-806D
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:39:19
Coding: 0532707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H04000 Serial number: 90025080880023
Coding: 0012341
VCID: 264310139112D62ECEF-8073
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Coding: 0048283
Coding: 0015510
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 79712 km
Time Indication: 0
Date: 2014.01.24
Time: 00:09:39
01915 - Lumbar Support Height Adjustment Sensor (G374)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 80936 km
Time Indication: 0
Date: 2014.02.23
Time: 16:45:02
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00001319200033
Coding: 0004078
Shop #: WSC 43906 002 1048576
VCID: 1D313FFFC44415F69F5-8048
3 Faults Found:
02104 - Light Detection Sensor (G399)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:20:00
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 62
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:28:00
02003 - Driver Identification Control Module (J589)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:43:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040804070053
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000022841
Coding: 0010111
VCID: 1E3338F3C9420EEE86F-804B
Subsystem 1 - Part No: 8K0 907 410 A
Component: UGDO HL US H04 0060
Subsystem 2 - Serial number: 1722240T05P401
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Revision: --H03---
Coding: 0000532
Coding: 0000018
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396D+087594608
Coding: 0000002
VCID: 2E53E833B9E29E6E36F-807B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000006790
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2804150146
Coding: 344530393135313035412056413032383034313530313436
Shop #: WSC 02391 145 00289
4 Faults Found:
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:41:51
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:44:41
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:47:51
02276 - Quiescent Current Stage 5
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:48:01
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000600055926
Coding: 0232125
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:25:37
Freeze Frame:
(no units): 0.0
Temperature: 28.0°C
Error Code: 0
Pressure: 0.00 bar
Pressure: 0.00 bar
Pressure: 0.00 bar
Pressure: 0.00 bar
Cannot be reached
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8310N7
Coding: 1120403
VCID: DCB7F2FB1FDEDCFE28B-8089
1 Fault Found:
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:28:30
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Cannot be reached
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740809603100
Coding: 0221208
Cannot be reached
4 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:28:05
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0°C
Temperature: 30.0°C
Voltage: 11.430 V
P0300 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:29:30
Freeze Frame:
RPM: 880 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000774 - Cylinder 6
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:29:30
Freeze Frame:
RPM: 880 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:29:30
Freeze Frame:
RPM: 880 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 30.0°C
Voltage: 13.843 V
Coding: 0000002
Coding: 0007597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV 2040
Coding: 4071648
Coding: 0000003
Coding: 0037185
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:39:19
Coding: 0532707
Coding: 0012341
Coding: 0048283
Coding: 0015510
Coding: 4071530
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 79712 km
Time Indication: 0
Date: 2014.01.24
Time: 00:09:39
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 80936 km
Time Indication: 0
Date: 2014.02.23
Time: 16:45:02
Coding: 0004078
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:20:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 62
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:28:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:43:00
Coding: 0032364
Coding: 0048686
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000532
Coding: 0000018
Coding: 0000002
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:41:51
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:44:41
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:47:51
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:48:01
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:25:37
Freeze Frame:
(no units): 0.0
Temperature: 28.0°C
Error Code: 0
Pressure: 0.00 bar
Pressure: 0.00 bar
Pressure: 0.00 bar
Pressure: 0.00 bar
Cannot be reached
Coding: 1120403
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 22
Mileage: 155300 km
Time Indication: 0
Date: 2017.07.05
Time: 01:28:30
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Cannot be reached
Coding: 0221208
Cannot be reached
Your scan shows Address 61 - Battery Manager has 'going flat' faults recorded on 5July at about 1.44. I'm not sure why you can't clear those.
You ARE running VCDS and Autoscan with the engine running, aren't you? Uwe Ross at Ross Tech is on record as saying the A8s pull the biggest load of all out of Batteries. Unless you have a charger that can supply 25A connected, you need to have the engine running to use VCDS for any length of time.
WIth the engine running, you can check the alternator output [it varies on A8s as they have an 'intelligent' alternator] but the 'battery voltage' should be above 13V with the engine on. [You're actually measuring the alternator output, not the battery voltage].
A8 batteries are typically about 90-100 AH [Amp Hours]. A flat battery at 11.7V will take hours to charge up to full [12.6V]. You need to get the battery up to 12.6V before you start analysing whether the battery or alternator is duff, but running the engine will [should?] provide the necessary voltage to power all the car's ECUs and run scans and clears.
Julian
11.7V is a flat battery. Roughly: 100% 12.65V, 75% 12.45V, 50% 12.24V, 25% 12.06V, FLAT 11.89V
Julian
Julian
Also when was last time it was tuned. Misfires across multiple cylinders but no codes for lean or something like that suggest maybe needs basic tune up. Or, maybe some bad coil packs if tune up is recent/already done.
To follow up...So it seems that the battery was the main cause of the problems I was seeing. I ended up going to the dealer for the battery. After coding in the new battery and clearing all of the codes things started to stabilize.
As far as the misfires, I am starting with a new mass airflow sensor that I will get installed today. Considering the age of the car, I will also work on getting the tuneup as well.
Thanks for the feedback...
marvgomez
Audi Original "S" Cars
10-23-2007 02:35 PM
Shaun
12-16-2000 08:42 PM
