Sponsored by:
Sponsored by:
D4 Headlights on a D3?
Old 06-13-2015, 05:02 AM
  #41
Banned
JohnnyJ A6Q's Avatar
Hello Dave,
That is not what I am talking about, I know what the Euro parking lights are, as I myself had a thread on that issue a while back, what I am saying is that as seen in this video made by Louis the fog light blinks opposed of turn signal, and I have seen this before on other A8's, I don't know why, maybe Louis can tell us why his was this way.
Johnny J J
Originally Posted by dvs_dave
That's the euro spec parking light feature, where you can have parking lights on, on one side only selected by the indicator stalk. It's not normally the fog lamp though as it draws too much power, rather the small 5W sidelight/parking bulb in the headlamp unit, and one of the tail lamps.
Old 06-13-2015, 07:17 AM
  #42
AudiWorld Wiseguy
dvs_dave's Avatar
If it's the same as Louis's then it's Jerry rigged electrics. I remember us all discussing at the time.
Old 06-14-2015, 09:11 AM
  #43
ltooz_a6_a8_q7's Avatar
Default It's a simple circuit design... Here is how it works
task:
- fog lights work as designed with LED bulb - turn on by fog light switch.
- fog lights blink with blinker.
- problem: can't connect fog light bulb to 2 different positive terminals: blinker & fog light - because if fog light switch turns on at night, blinker will be constantly on.
Solution:
- use positive terminal of blinker as negative of fog light bulb - which is always low, only high when turns on = 12V.
- Fog light will turn on at night because the negative from blinker is low - but when the blinker is on = 12v - the negative of fog light led bulb = 12V ==> the voltage across LED bulb = 12V-12V = 0V=OFF, that's why it's off.
Therefore - if blinker is on and fog light switch also turned on - fog light bulbs are opposite to the blinker bulbs.
In the Video: The Fog Light LED bulbs positive are connected to both parking light and driving light positive since only one can happen at one time - either parking or driving and not both. The negative is still connected to the Positive of the Blinker bulb. Hope this makes sense.
Cheers,
Louis
Old 06-20-2015, 09:44 AM
  #44
Jack88's Avatar
Originally Posted by RangeK1D
That LED retrofit is very nice! The 2015 LED design would look absolutely killer on our D3 headlights. Check out the images below, food for thought.
To my eyes, that looks simply awful, whether it works well or not.
Old 02-11-2017, 02:27 AM
  #45
Carsten Haag's Avatar
He's done such a great job wiring it all up that the left fog light is out, but the corner marker is on, and opposite on the other side. Would like to see a pic of his dash too. I bet it's lit up like a Christmas Tree with bulb out and headlamp range control errors .
Actually I think the fog light is on, because the steering wheel is turned that way. Its cornering light
Old 02-11-2017, 04:55 AM
  #46
Jack88's Avatar
That's a good point. Forgive us in the US, cornering lights aren't enabled from the factory, if I recall.
nate
Audi A3 / S3 / RS 3 MKII
10-12-2021 12:44 PM
Raistlin
NY / NJ / CT Discussion
03-21-2008 12:19 PM
DelSol
Audi A3 / S3 / RS 3
03-27-2004 04:09 PM
Det. Mickylaren
07-12-2003 08:38 AM
sukebe
08-21-2002 09:24 PM
Quick Reply: D4 Headlights on a D3?
