Driver door handle removal
#12
I'm about to replace the passenger handle. Once you have the door apart, and the latch out, are there any hints or tips for removing the handle itself or is it pretty straightforward? Just want to be prepared in case there are any special tools I might need...
#13
Well, I didn't get any responses, but went ahead and replaced the passenger door handle today anyway. It was easier than I thought, once the door was apart. I had assumed the door latch would have to come out, but it didn't. Once the door was all the way apart, I just unthreaded that grub screw in the handle (through the small hole in the side of the door - long hex driver) and the handle assembly came apart. Cleaned up the surfaces, fitted the new handle and tightened it back up. The body shop did a great job with the color, they used the Audi color code and it is an exact match. Best of all, no Channel 52 VCDS error code any more! I'm testing the lock/unlock and battery drain now. I'm going to do the driver's door tomorrow and take photos as I go (forgot to do that today).
#15
#17
Many Thanks for This DIY Writup
Got the handle used here for $24. Already the correct color and works perfectly:
https://eurochopshop.com/product-cat...e=door-handles
#20
Take the glass out of the mirror, disconnect the loom from inside the mirror one connector at a time and it comes out of the housing still attached to the car. Feed loom back into the new mirror and reconnect. Saves hours of work!
