Driver door soft close
Doesn't work anymore and there is a noise when closing manually. Any ideas on easy fix?? Probably have to remove door panel- is that difficult?? Thx
Door panel removal
1 Attachment(s)
Check out the PDF. Behind the panel is a metal frame. I don't know how that one sits though but search the forum and I guess you'll find out.
Hilden:
I have sent you a PM
Will send you a pic. Too bad though I didn't know about that 2weeks ago when I had everything torn down and I could've given you much better details :)
Thread hi-jack - How do you add control of the Webasto aux heater to the MMI?
Hook up VCDS. Check that module 18 - aux heater is activated. Then go to module 08 auto HVAC, click Coding 07 and add 2 to the existing coding. Save, exit, ignition off and when you turn it on again you should see the timer menu under ACC setup menu.
Did it today - works fine thanks.
driver door soft close
Originally Posted by FischerWausau
(Post 24091989)
I'm have having the same problem with my drivers door
anyone have anymore info on this?
