Fix broken glove box frame
So, after monkeying with the glove box and I noticed the left frame was separated and the triangle hinge was loose then fell off after trying to glue it in place. I remembered I had the BOSTITCH heavy duty staple gun. Put everything in place as it wasn't broken, tight and aimed with the staple gun, not really centered but it worked. Solid as a rock.
Cheers,
Louis
Cheers,
Louis
While effective, that's less a fix, more of a MacGuyvering! I might suggest hitting it with a black marker or something so it is less obvious. Still, saves you some money, effort, and it still works.
maximumdownforce
05-13-2005 12:48 PM
