Harsh Ride On Bumps & Slight Knock
2010 4.2 tdi sport
Guys. My front suspension seems a bit harsh when going over bumps, its like the tyre pressures are wrong however they are fine, some holes in the road give me quite a thud. I have developed a slight knock on the drivers side when going over a slight bump, it sounds like the ARB bushes but may well be something else. Any suggestions where to look guys. The car passed its mot recently and had no advisories.
The Transporter
You're probably going in the right direction - bush / control arm. Have a look. Mine is starting to wear on my driver's side and I can feel it especially when cold.
Regards
Naudi
Regards
Naudi
Thanks for your reply. Im hoping it is just some bushing that needs replacing. I already replaced one of the control arms due to hitting a wheel off a kerb.
The Transporter
Check the arms too. It's one or the other more than likely. When I start the car on a cold day and start my initial back out and accelerate forward, I can hear a thud as I go over slight bumps and turn my steering wheel. It's usually before I'm cruising; the Audi dealership said the drivers-side control arm was probably the culprit. So far it hasn't been problemsome to me or my woman, but when it is, I'll fix it. The ride on these things are too sweet not to!
I should chime in and say the bushings for all four of my upper control arms were shot, and it turns out the bushings on the lower control arm where the strut mounts to are shot as well. Despite that, the car rides smoothly and quietly. Just not as tight as it surely used to be. Clunking or a crunching noise is typically sway bar links, if I recall.
Yes it does sound like the sway bar links. Is it safe to assume all my main bushes should be ok if it passed an mot? Maybe the harshness is due to the 20" wheels and the sport suspension. I have to say i cant notice any difference between comfort mode and dynamic mode when i change the suspension settings. IS it obvious?
Read Jack88 comments, control arms systems are different, if your tires don't wear out badly like mine, then it's not the control arms, it's still smooth even if mine was bad.
It's also old tires where the walls turned stiff. The air shock may be over inflated and the eshock stuck at stiff mode.
Before replacing good parts, check and verify the parts first, I do have a video on how to check the upper control arms.
What's up with people with CA, everything is CA?
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
I haven''t driven my car with new bushes but even tho it rides smooth, I can tell it's not right, not how it should be...
It's in for it's 10 year service at Audi next week, part of that is checking suspension, I well expressly ask them to check all the bushes...
Then promptly get someone else to change them for a tenth of the price...!!
audinutt
09-27-2008 03:20 PM
BoneStockS4
03-04-2005 05:32 AM
Distinct
07-27-2004 09:47 AM
BrianHoward
05-27-2003 09:47 AM
