Head lamp high beam adjustment..
Hi guys, I've looked on here, and searched the net, but can't find a way to independently adjust the high beams on the car (mine are wayyy too high). I see the two covered 'hex' adjusters, but they're for low beams, right? The auto level is working correctly...apparently.
Anyone? K9 |
Are you talking about HID high beams or halogen ones?
HID's are changing low/high by shutter and I believe only low beam can be adjusted. Halogens are used only as a flash lights in US and I think they can't be adjusted at all. |
Thanks Mishar,
My car is set to 'ROW' so I have the Halogens as the high beams, mainly so I don't have to deal with the 'candles in jam jars' as headlights.:mad:
Can't be adjusted? That makes sense.... in a relative away. K9
Originally Posted by mishar
(Post 24340371)
Ummmm, didn't you just get a copy of the erWin instructions ? ;)
If all else fails: https://www.surplusjeep.com/MB-GPW/I...ght%20assy.jpg http://www.classiccarcatalogue.com/H...minxPhaseI.jpg |
You are right about halogens height. They are more like marine lights. Full blast not corrected beam.
Jake, that one is for a wrong side traffic. :) |
(Post 24340529)
But I guess it would work on the wrong side of the road too ;) |
Jake, yes I did, couldn't find anything in there....
Wrong side traffic? Seriously? You lot have only had the car five minutes and look at the mess you made of it already:D. I give you Corvette and CTS-V. ;)
K9
(Post 24340529)
