Heated/Vented seat controls on driver side control both sides
Hi,
Strange problem:
When turning on the heated seats or vented seats with the drivers side controls, both seats are heated or vented. Other settings are strictly working on the correct side. When using the passenger side, they don't work.
I can access both control modules with vagcom, and they have a different coding.. So they know which side they are..
Anyone came around this before?
greetings,
Erik
Strange problem:
greetings,
Erik
For OP, not specific to seats, but sometimes folks have posted about the settings being completely reversed, even if settings are different from side to side. It's been a long time, but can you see the seat settings on the MMI display like other HVAC stuff? If so, is it displaying correctly even what you are doing with the controls aren't correct as far as actual functioning?
Hi,
Controls are working as they should. Images on MMI are correct, lights on the ***** are correct. Strange part is.. setting the seat ventilation with the drivers button, turns on both front seat ventilations. Pressing the passenger site button, nothing happens (besides the controles on the screen etc showing the right things)..
There is HVAC setting called "sync" or similar. Maybe that is turned on? Pressing and holding in the HVAC temp **** will also enable sync mode. Just a SWAG.
neumanngroup
17
09-18-2020 01:29 AM
Waggin
Audi A3 / S3 / RS 3
14
02-13-2006 09:55 AM
RichieB5
02-10-2006 09:38 AM
