help please a8l tyre baulding bad
hi is there anyone who can help i have a audi a8l 2007 i have replace all the arms and d links myself plus change the lower links with adjustable ones all my tyres were brand new at the time but now they have worn right down to the canvas on the inside edge were the rest of the tyre is still at 7mm any idea's would be great thank you
Upper control arm bushings. Search--post on probably 200+ times now, including (by me) the tire wear aspect.
Honestly, if you replaced all the arms, that may be counterproductive. I would always prefer used OE lower arms showing no obvious issues over "great deal" kit of dubious origin and/or quality. D3 issues are limited to the upper bushings 95% of the time, esp. if you see the oft confirming tire wear.
If you have adjustable lower arms because the car has been lowered, what I would do is set the car height to factory specs, put good OEM upper and lower arms on it, get a 4 wheel alignment, and 4 new tires and call it done.
thanks for all your reply's all the arms were gen ill get the aliment done and see how it goes
I was/am having similar issues with inside edge wear. Replaced upper control arm bushings & tie-rod end u-links....though on inspection when I removed both neither really needed it.
Had an alignment done at my local independent shop, to both of our amazement things were really not out of spec (most was in spec, some was barely out of spec...and I mean barely).
Nothing else was blatantly obvious as an issue - though I've spotted that my lower arms may need inside bushings (but was thinking that would more likely affect caster rather than camber...but maybe I'm wrong).
So....I'm on the hunt for a similar smoking gun before replacing tires (which will need it soon).
Did you look at the inner bushings by really moving them around, like sticking a screwdriver through them and torqueng/twisting them to the sides? Or on the car, checking them completely detached from the steering knuckle/hub end by undoing the pinch bolt? Putting aside the occasional horror story picture of completely torn out bushings with long term neglect, I found you really don't see visually huge issues if you either try to inspect them in place with arms still bolted in on both sides, or even if you look at them loose just sitting there. You have to flex the bushings to see if there are deep cracks or not, or if it is even partially detached in places but not yet looking torn out. See my replies ##19-22 is a thread I did with pictures. https://www.audiworld.com/forums/a8-.../#post24620404 In the car those looked like they were arguably okay, but some were not good once I tweaked them with screwdriver or moved them after undoing pinch bolt as I pulled them out. I think what happens when they get like that is under braking especially the geometry of the suspension ("alignment") changes, but only during that braking action. But that in turn is exactly the sort of thing that can grind up the tires.
