How do you know if you're compressor is on its way out?
#21
If you are seeing 16 Bar when the compressor is running, then there is nothing wrong with your compressor. It’s working to spec (<8 Bar seems to be when codes become more regular, eg overtemp, implausible pressure signal, low ride height etc). When the compressor shuts off, the pressure in the supply/exhaust line will naturally bleed off via the non-return valve and exhaust solenoids located within the compressor assembly. At that time the sensor is only measuring the pressure in the supply/exhaust line from the compressor, nothing else. This residual pressure reading is pretty much irrelevant and has no bearing at all on system performance.
#23
Sully
02-08-2005 12:28 PM
Ghostfire
09-22-2004 06:28 PM
ZesTTee
10
03-07-2003 08:40 AM
S4er
10-18-2000 12:03 PM
TommyK
03-03-2000 06:36 PM
