Instrument cluster / headlight out of range
I started getting a weird instrument cluster issue. Sometimes they won't come on when I start using the ignition button. The gauges do not work either. The clock resets and the light brightness of all instruments goes to 100% and the trip computer rests. I then sometimes get a headlight out of range warning.
If I shutdown and restart it usually works but everything still resets to default values. If I just leave it running and wait the instrument lights and gauges will come on in about 30 seconds and be fine.
What is going on here? Getting ready to sell and need to have this issue squared away.
2008 A8L 4.2L
2008 A8L 4.2L
Flaky electrical is often a failing battery. How old is it? VCDS or similar scan--not just OBDII generic though--would probably give you a lot of error code further pointers.
I replaced the battery. I was not sold the proper battery. It was a Varta but not the correct one. The one I got from the dealer is about 20% wider.
I am not getting the headlight out of range warning on the dash anymore but the time is still resetting and the gauge cluster illumination is resetting. I am not getting any codes in VDCS.
Could this be the battery monitoring control module? Wouldn’t that throw a code?
Clear all the codes for starters--module by module--and see what comes back and issues you then still have.
Also be sure you connected the little wire at the main positive battery terminal, and that it didn't get broken. That is key for the power management system/module.
The headlight out of range one (and a dash light) you mentioned is common with any battery disconnect. Drive the car a block and it self resets--as I think you found.
Actually better with the bigger battery as long as it fits. There are two common sizes used in D3's (plus a third IIRC). They all physically fit, and I'm a believer that on older cars "bigger is better" anyway. In some years the 4.2 came with the bigger one, but not in other years. Oddly my W12 was not spec'ed for the bigger one either, but given all of motor size, mountain cold starting and all the power suck options, it was a no brainer to use bigger one. Dealer had already changed it previously, also using the bigger size.
I was sure to make sure that little wire was squared away. I’ll doible check it though tomorrow.
I did clear all the codes. Nothing has cane back in two days.
Thanks for your response.
Headlight out of range is gone, but the date and time still reset as well as the instrument cluster illumination gets reset.
Checked all the fuses. All good and seated properly.
Codes I am getting now after clearing everything one by one.
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 D HW: 4E1 907 560
Component: 4.2l V8/4V 0010
Revision: 71H21--- Serial number: AUX3Z0GD738692
Coding: 01060009190F0120
Shop #: WSC 02313 785 00200
VCID: 23B03E0322DAA80AF85CD2-8076
1 Fault Found:
049493 - No Communication with Instrument Cluster
U0155 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 46.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4406275
Coding: 0000002
1 Fault Found:
U0155 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 24.0
Temperature: 56.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 BQ
Component: ESP 5.7 allrad H49 0540
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2AAED32745F07942BB9A87-807E
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0GD738692
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 584A59EF2B1C3BD2DD4E9D-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 2040
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 24B23D1F27D4AF328156D9-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348L 077527344
Coding: 0000003
VCID: 22BE3B073DC0A102F36A2F-8076
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000053814
Subsystem 3 - Serial number: 0111.12.070000000100010166˙
Subsystem 4 - Serial number: 010166˙
2 Faults Found:
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 32
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
01043 - Control Module; Incorrect Software Version
000 - - - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 72
Time Indication: 15
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000138868
Coding: 0102737
VCID: 1CC205FF1FA497F2392661-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO20122007065A000000000004˙†89
Subsystem 5 - Serial number: 000004˙†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO19122007065A00000000
Subsystem 7 - Serial number: 65A000000000368˙
3 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:09:42
Freeze Frame:
Voltage: 11.70 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:09:42
Freeze Frame:
Voltage: 11.70 V
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143123
VCID: 388AF96F8B5CDBD23D0E3D-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 27A82A1356E2842AA4B4E6-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0222608
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F98C2337E121C6A6CE45E-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 25
Mileage: 174106 km
Time Indication: 0
Date: 2018.12.09
Time: 00:35:59
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV0001CN$
Coding: 0532707
VCID: 29AC2C2B40F6725AB2A090-807C
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 01S07
Subsystem 3 - Serial number: 0001.01.0000H0200000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB40346E580I˙†63
Subsystem 5 - Serial number: 6E580I˙†63428RB40346F5A9V˙†63
Subsystem 6 - Serial number: 6F5A9V˙†63528RB40346E5B1O˙†63
Subsystem 7 - Serial number: 6E5B1O˙†63628RB40346CB94U˙†63
Subsystem 8 - Serial number: 6CB94U˙†63729RB4030BCF8F4˙†63
Subsystem 9 - Serial number: BCF8F4˙†63829RB4030BC322H˙
Subsystem 10 - Serial number: BC322H˙
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H04000 Serial number: 90055073140013
Coding: 0012341
VCID: 26B6271751E85D229F42F3-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 72
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 K HW: 4E0 920 951 K
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3GD100083
Coding: 0048283
Shop #: WSC 58444 001 1048576
VCID: 2DA4D83B741E6E7A5EF8A4-8078
4 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 2
Reset counter: 20
Mileage: 173760 km
Time Indication: 0
Date: 2018.12.08
Time: 00:00:26
00381 - Databus Instrument Cluster
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 0 km
Time Indication: 0
Date: 2018.12.09
Time: 00:00:00
01298 - Instrument Cluster Lamp Test
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 22
Reset counter: 72
Mileage: 0 km
Time Indication: 0
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07C0782E8
Coding: F5F5DF7F707A0E00
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046007 Serial number: AUZ5ZBG3521982
VCID: 18CA19EFEB9CFBD21DCE5D-804C
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000064392
Coding: 0000000
VCID: 613C740B7846FA1AAAF078-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2BA0D6234A0A604A408C8A-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395L1077507584
Shop #: WSC 24111 444 72525
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000731700080
Coding: 0003477
VCID: 1DC408FB04BE9EFACE1814-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 20BA310F33CCB312E57E35-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040712180046
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 32
Mileage: 163589 km
Time Indication: 0
Date: 2018.05.13
Time: 16:00:37
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000007101
Coding: 0000026
VCID: 2CA2D53F4F0467724986B1-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000015185
Coding: 0010111
VCID: 1EC60FF709B885E2D7121B-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T01WJ07
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
Shop #: WSC 24111 444 109184
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 59
Reset counter: 72
Mileage: 8 km
Time Indication: 0
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396L4077586822
Coding: 0000002
VCID: 2EA6DF377918156267F2AB-807A
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000019660
Shop #: WSC 01307 444 83773
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 2712080847
Coding: 303030393135313035444C56413032373132303830383437
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700055564
Coding: 0232125
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000712130070
Shop #: WSC 12336 024 394758
VCID: 3492CD5F97343FB2113669-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7Y11DB
Coding: 1120503
VCID: 5C4245FF5F24D7F2F9A6A1-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740734903156
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005019604
Coding: 0010900
VCID: 25B4201B2CEE563A9648CC-8070
End-------------------------(Elapsed Time: 03:45)--------------------------
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 46.0°C
Voltage: 11.938 V
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 24.0
Temperature: 56.0°C
T.B. Angle: 0.0°
Coding: 0007597
1 Fault Found:
Coding: 0410624
Component: ELV 2040
Coding: 4071648
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 32
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 72
Time Indication: 15
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10
Coding: 0102737
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:09:42
Freeze Frame:
Voltage: 11.70 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:09:42
Freeze Frame:
Voltage: 11.70 V
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Freeze Frame:
ON
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 25
Mileage: 174106 km
Time Indication: 0
Date: 2018.12.09
Time: 00:35:59
Coding: 0532707
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Coding: 0012341
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 72
Mileage: 174218 km
Time Indication: 0
Date: 2018.12.13
Time: 00:11:06
Coding: 0048283
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 20
Mileage: 173760 km
Time Indication: 0
Date: 2018.12.08
Time: 00:00:26
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 0 km
Time Indication: 0
Date: 2018.12.09
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 72
Mileage: 0 km
Time Indication: 0
Coding: 0000000
Coding: 0015510
Coding: 4071658
Coding: 0003477
Coding: 0032364
Coding: 0048686
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 32
Mileage: 163589 km
Time Indication: 0
Date: 2018.05.13
Time: 16:00:37
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000922
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 59
Reset counter: 72
Mileage: 8 km
Time Indication: 0
Coding: 0000002
Coding: 0032364
Coding: 0232125
Coding: 1120503
Coding: 0032364
Coding: 0221208
Coding: 0010900
