Introducing SuperSprint's S8 cat-back system
#11
S8's (and W12's) have valved rear final mufflers. Smaller diameter open outlet, larger diameter valved outlet. Without a valve, I expect torque to be down marginally with lower back pressures at low RPM's on a normally aspirated motor like either the D3 S8 or the W12. And since the car is set up with the valve and electronics, it can still open up for the greater flow at high RPM's.
Am I missing something, or is this more a nod to the boy racer sound?
#12
SuperSPrint's X pipe is 650 + S/H and can be purchase separately. The resonated X pipe is 999 + S/H.
USA S8 (1749);
2007 - 1144 Units imported
2008 - 396 Units imported
2009 - 209 Units imported
All the stock exhaust is missing is the x-pipe, here's one for $1500, but a muffler shop could perhaps fabricate a similar one for less;
http://www.gmgracing.com/audi_exhaust_gmg_wcs8.shtml
#13
Agreed (with Mike and EHLO) that...
Agreed that the valves are designed primarily to quiet the car/reduce droning at low RPM's. That's what the Audi W12 shop training documentation says. But, the old classic tuner's caveat on exhausts for normally aspirated engines that I'm factoring in was that a "cost" of opening them up for higher flows with less back pressure at high RPM's was some loss of torque low down where the back pressure can actually be a good thing with typical intake and exhaust valve overlap. Hard to know exactly how that gets interpreted now in an N.A. configuration on a modern Audi motor with variable valve timing, multivalve motor, multipath intake runners and the like.
Audi's W12 documentation does says the secondary flap only opens when all of these conditions are met: >3mph; engine load>50%; engine speed >2500 rpm. Given other similarities in the S8 and W12 intake and exhaust set ups, fair to guess similar parameters likely apply to the S8. Thus in the case of high load but low engine speed the flap isn't open--also fits the old rule of thumb to pick up a bit of torque at lower RPM's where it is weaker in general. In the real world with an automatic that would likely be holding the gear in tiptronic mode while getting on the gas below the full throttle point. The Vette option for the valved exhaust set up on the base motor shows it adding 6hp and 4 ft pounds overall in a motor with HP and torque specs in the same league as W12's and S8's, so overall differences here will presumably be pretty subtle rather than butt dyno obvious. And notice, they still opt to do it with valving even in an optional package rather than leaving it open all the time. The Vette specs also fit with the other general rule of thumb that in an NA motor with a well thought out exhaust to start, hard to squeeze out much more real power. Tuned turbos and especially full exhaust (as Mike alluded to earlier in the thread), different result.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
