Jacking mode
Will Rhino ramps fit under the bumper without the car in jack mode?
The car knows it's being jacked up. SSP #??? says raising the car quickly helps in this regard.
You can reset the MMI with a three-button combo (I can't recall, STFA) but not sure it'll help.
Be sure the battery is good, either have a 15A charger hooked up ( "-" goes to big hex post above the battery) or the engine running.
hth,
Tom
hth,
Tom[/QUOTE]
Rolls right on, front or rear. I looked at doing my first oil change in lift mode. Could not get under the car. The jack mode has no effect when using ramps.
