leaky valve seals??? and other issues
#21
Have you looked at engine pressurizing scenarios BTW? Start with the basic take the oil filler cap off while running and see if either highly pressurized or it affects idle. If so, start searching on prior S8 posts or other V10 owners' experiences. Each motor seems a bit different in what kind of pressurization is found, with common connection being something in the PCV/oil separator function.
#22
got it running again!! i replaced all of the injectors. probably a bit excessive, but to have them serviced was nearly as much as buying them new. and there were probs with all of my injector service people. it was going to take at least a month for injector cleaning.
i doubt ive stopped any of the leaks, but need to put some miles on it first.
pulled the oil filler cap off while it's running, it has a healthy amount of suction. so no over pressurization in the oil cavities.
also went down some steep hills in 1st and 2nd gear keeping high revs. no smoke that i could see. no pops, no bangs, no drama, no misfires. i just looked silly with my engine all revved up. oof
after getting everything cleaned up and reading a bit more, i think that it's worth looking into the oil cooler more. it seems like the most significant leak come from the front right of the engine, right where the oil cooler is buried. i've found plenty of info on the v8 oil coolers, but haven't found anything on the v10 oil coolers. i'm assuming there are o-rings?? maybe a gasket?? prolly some crummy plastic piping?? i think i can tackle it blind, but seeing the process ahead of time helps to pull in parts.
some of the injectors were destroyed while i was removing them. i had a known issue with injector 9, but i wonder if some of the injectors were leaking a bit?? and maybe my uglier valves were an indication of pre-ignition and a rich condition?? i hate trying to make my problems neatly fit into the solutions i've provided, but it seems like it could be possible.
#23
doing some searching, i've found that the oil cooler has 2 o-rings on the block side that are 24mm x 2.5mm. i'm not sure if there's anything else going on back there, but should just be an oil supply and return. hopefully they're just standard o-rings???
i do have a bit of oil collecting on the oil pipe just underneat the front of the engine. but i'm thinking about just tackling the oil cooler first.
found this drawing that helped - https://www.jimellisaudiparts.com/sh...roduct=5432570
#24
i replaced the cooked o-rings in the oil cooler. that cleaned up the majority of the oil leaks i've been dealing with.
but there's still oil coming from the main seal. the oil additives do nothing.
so i need to pull the engine. it looks like the engine could come out the front when the front end, bumper support, and core support are removed. is it really necessary to drop the engine and tranny out the bottom?? or is there some magical way of replacing the rear main seal without pulling the engine??
seattlematt (09-15-2020)
BoneStockS4
09-09-2006 07:47 AM
JaXeN
01-28-2006 11:01 AM
nkk@auto
02-19-2003 11:15 AM
sidespar
07-02-2001 04:16 PM
