Lean codes bank 1 and 2
Well, I don't know what I did to anger the gods at Ingolstadt, but no sooner than I get my suspension back up and running properly, I get a check engine light for banks 1 and 2 running lean. The car seems to run and drive without issue at the moment, the only possible symptom I noticed before the light was sometimes on startup it would rev to 2200-2400 rpm for a few seconds before settling down to normal and today on a warm start it hit idle speed for a moment, dipped to 500 rpm momentarily and returned to normal rpm. All of this is in park still, by the way. My suspicion is the fuel pump that only operates during startup is failing, and that seems to be the suggestion that usually accompanies these posts. I can't remember which pump is the one for start up off the top of my head. Really, I'm just fishing for alternative explanations before I just order an OEM pump at $346. Man, I don't think anyone else on this forum has bought a running and driving car that has had so many things to address that didn't come about from negligence or abuse in such a short time. I have had the car since March and not even put 2000 miles on it!
Most common area for lean codes on both banks would be an air leak on the intake side before you get to the intake manifold itself. If it is both banks, look particularly at anything between the MAF and the intake manifold----those last couple of clamp connectors, throttle area, any hose take offs there and the like. After poking for an air leak; confirming air pump is working and its hoses connected, free and not compromised; and watching for any SAI codes, then perhaps suspect the MAF. You can check its flow rate readings by instrumenting it with VCDS and going for a drive. Its peak flow rate in grams per second should be 80% or more of rated HP as a rule of thumb. Rounded off (you can do the calc), that means at least 250 g/s flow. Peak flow that is easy to read is typically near redline out of 1st or 2nd. Either record the test run via VCDS, or have a ride along partner to watch the data while pushing last thousand or so RPM in probably second. On an older ride, worth knowing an MAF is still up to snuff for smooth operation and power.
And yes, it could ultimately be a fuel pump. The transfer one can show up when car gets flaky yet gauge says it has gas. Posts that I recall casually on it are more like car dies completely, but indirectly I think the transfer pump is not moving fuel across the hump of the tank to the other side, so main pump runs dry. Main one can also just get weak or crap out completely. But that's just very casual description; there are better ones in the D3 and 4.2 port related SSP's about how the fuel pumps work. The FSI ones have another set of high pressure pumps, but not relevant pre 2007 for 4.2s (or any D3 W12).
Ah, according to the diagrams I'm seeing, there are 4 pumps in total. A transfer pump and regular pump on both sides of the tank. I had thought that one pump was used only during startup but I wasn't sure. I'll look into it and the things you have suggested.
I think you will find there are two actual pumps--things with motors, or more generally moving parts. The other things referred to as a pump probably are Audi's terminology for suction/vacuum creating devices (like vortex shapes and/or orifices) and related lines, like here to pick up fuel. Always confusing to me when they call something a pump, yet it doesn''t have moving parts. The FSI motors have four actual pumps--same two in the tank and then one high pressure one (HPFP) on each cylinder head. D4 simplified it to one tank pump that can pull fuel over the saddle/hump without needing two in there.
AudiWorld Wiseguy
There are two pumps in the tank. A primary and a secondary. Primary runs constantly whilst engine is running. Secondary pump runs for the first 30s of startup and under higher throttle openings. Both pumps feed the engine fuel rail, and also fulfil the fuel transfer role by way of them both being connected to the two suction jet pumps, one for each side. It’s the suction jet pumps that actually transfer the fuel from side to side. However they are driven by the fuel pumps, be it just the primary pump, or both pumps at periods of higher demand.
Classic primary pump failure is both banks lean with no vacuum leak, and/or engine stalls 30s after startup when the secondary pump shuts down. If no vacuum leaks or obvious pump failure, then a dirty fuel filter could also be the cause.
Deteriorating pump performance problems are tricky to diagnose though as the pump performance is not specifically monitored; rather you get consequential symptoms showing up elsewhere.
Check out SSP 282, p34 onward.
http://www.volkspage.net/technik/ssp/ssp/SSP_282_d1.pdf
AudiWorld Wiseguy
Yes, probably best to see if any other symptoms manifest to get a better point on what it could be.
FWIW, and to avoid going on a wild goose chase, SAI system faults won’t throw generic lean codes. The system performance is specifically monitored so has it’s own set of specific SAI fault codes.
Let me add..
Okay, so what I think I will do is change the fuel filter and see what happens. I don't think it has been for about 50k miles at least, maybe original, hard to say. Perhaps if that doesn't do it, I'll just have to wait until more obvious symptoms show up to make a diagnosis.
P310B/012555 - Ross-Tech Wiki
AudiWorld Wiseguy
tomwu
12
01-08-2019 04:20 AM
Audi-Impaired
10
03-02-2004 06:20 PM
