MMI: Center console issue
#11
And when I got back from my four-day trip, the battery was discharged and I started using a jump starter and the battery is now working normally. The problem is, the odometer display is not working and, as I said, Hughes is all normal.
#12
Hello Albert,
Are these picture from after the cleaning, your board has corrosion (green/bluish) at solder points, you can either clean it lightly wire brushing it and then hot air re-solder flux the areas, if you do not have those tools or are not comfortable doing said job, you can get the board off of ebay.
https://www.ebay.com/itm/New-AUDI-A8...2b4268942ca698
#13
I replaced the link for ebay as your board has the 2004-06 style layout of the micro switches, you did state that you have a 2007, was that a typo?
2004-06 board VS. 2007-09
#14
I have identified the year of manufacture by looking at the vehicle's vehicle license number and confirmed it was manufactured in 2006.
And since this car was registered in 2007, I knew it as a 2007 model.
#16
Good day Giovanni,
I bought and installed a used mmi control panel ( I already check part-number is same) but still have no power.
Can you tell me another way?
#18
Hello Albert,
For the $130.00 I would have purchased the new panel instead of used, how do we know if the used unit had failed prior to removal.
Next, we will need a scan to show if control head #07 is reachable or not as shown in attached picture, you must do the optical bus diagnostic test.
hurstkuo
Q7 MKII Discussion
46
05-09-2023 09:52 AM
Cap101V1organ
01-28-2012 08:33 PM
tjn k04'd
01-24-2006 07:51 AM
