Sponsored by:
Sponsored by:
MMI update!!
Old 11-18-2013, 03:39 PM
  #11
Smitty5534's Avatar
I'm in North America
Old 11-18-2013, 06:26 PM
  #12
mishar's Avatar
Originally Posted by mishar
To update MMI software you need working CD changer and Update CD's. Buy them from a dealer. Part number: 4F0 998 961
In the mean time search for MMI update here. There are many treads.
Have you tried that blue link in my previous post? Those guys will sell it for ~$25.
Old 11-18-2013, 08:30 PM
  #13
Smitty5534's Avatar
Yes I tried it but with shipping it would be close I thought I would just pay a little more money and for sure have it in two days. My question is how am I going to install these disks to the mmi if the mmi system neve makes it through the first boot. I know you put it in the cd changer but does it start up install as soon as you put them in?
Old 11-18-2013, 09:16 PM
  #14
mishar's Avatar
You have to start it from MMI, but that is problem. May be somebody has some idea?
Old 11-19-2013, 03:49 AM
  #15
jakematic's Avatar
Post a complete VCDS scan please.
Maybe something will pop out at one of us.
Old 11-19-2013, 04:29 AM
  #16
Smitty5534's Avatar
I will post a scan when I get home later. I think I might have an idea tho. The control head I got they had satellite radio installed and I don't. It looks like someone bypassed it or that's how it comes from factory if you don't have that option.(it has the power plug and the connections but the fiber optical is connected to a bypass ring). How do you uninstall a component off the gateway list. I believe the first thing it try's to communicate with is the satellite radio and when it can't it shuts down? Any thoughts on this? Thanks
Old 11-19-2013, 05:51 AM
  #17
jakematic's Avatar
Default Module 19
I think that was what Louis was referring to in his response.
Originally Posted by ltooz_a6_a8_q7
Make sure you don't have any extra stuff selected on the gateway from the x-car.
Go to CAN gateway and choose Installation List
http://www.ross-tech.com/vcds/tour/i...tion-list.html
Old 11-19-2013, 12:22 PM
  #18
ltooz_a6_a8_q7's Avatar
I believe the CP and all problems come from devices selected mismatched with the original car. You can add more devices and verified but not store more devices which can't be verified. The reason I think this is true because I added a used Navigation to the Q7 and it didn't give me the CP at all. The CP is just for the Dealer to restore to the original configuration of the car when it was built.
I believe everything we added through the gateway, stored in the MMI head unit to control all devices selected in the gateway, when MMI head unit uses the device list (stored) and can't find them, it throw a CP to tell you to go to the dealer and get it restored to the original configuration.
Make sense?
It's always best is to print out the list of original equipment so we can come back later to edit the gateway.
Cheers,
Louis
Old 11-19-2013, 01:17 PM
  #19
mishar's Avatar
Make sense?
Yes, but it is not so. Component Protection is actually theft protection. Once installed SOME components register VIN and won't work properly when installed to an another vehicle. Dealer has to be online with central Audi database (probably with the list of all stolen vehicles) in order to remove Component Protection and enable it to work with new vehicle.
Navigation unit is not protected this way.
Old 11-19-2013, 05:35 PM
  #20
Smitty5534's Avatar
Heres a scan:
VCDS Version: Release 11.11.3
Data version: 20120401
Tuesday,19,November,2013,21:30:58:32264
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E74N003196 Mileage: 168560km/104738miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C4514519
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F47FDA5CEA6FD1
4 Faults Found:
18348 - Powertrain Databus
P1940 - 008 - Missing Message from Control Module for Battery Monitoring
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
18282 - Valve for Torque Support Mount
P1874 - 001 - Short to Plus
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0031986
Coding: 0000002
VCID: 244DF249E7C0DE9
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2143FB5DF8D2CB1
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H02 0120
Revision: 01203602 Serial number: AUX3Z0C4514519
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 97
Mileage: 168320 km
Time Indication: 0
Date: 2003.02.27
Time: 17:53:26
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 234FF155E2CED91
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 105
Mileage: 160028 km
Time Indication: 0
Date: 2003.03.16
Time: 05:41:05
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000017152
Coding: 0037313
VCID: DAB10CB11504D89
Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Component: Sitzluefter BFS H05 010
5 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Mileage: 168321 km
Time Indication: 0
Date: 2003.02.27
Time: 17:52:28
Freeze Frame:
ON
Bin. Bits: 00001111
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 7
Reset counter: 142
Mileage: 168328 km
Time Indication: 0
Date: 2003.02.27
Time: 08:43:42
Freeze Frame:
Voltage: 13.40 V
(no units): 155.0
(no units): 255.0
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 233
Mileage: 138172 km
Time Indication: 0
Date: 2003.02.27
Time: 02:40:07
01869 - Left Rear Cold / Warm Air Outlet Motor Position Sensor (G351)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 138
Mileage: 168392 km
Time Indication: 0
Date: 2003.02.27
Time: 12:50:30
Freeze Frame:
Voltage: 13.40 V
(no units): 149.0
(no units): 255.0
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 140
Mileage: 168404 km
Time Indication: 0
Date: 2003.02.28
Time: 04:37:12
Freeze Frame:
Temperature: 25.0°C
Speed: 56.0 km/h
(no units): 193.0
(no units): 255.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A511C7185E4089
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02313
1 Fault Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 105
Mileage: 167186 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:05
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H08 0820
Coding: 0530707
2 Faults Found:
01742 - Igniter for Knee Airbag; Drivers Side (N295)
001 - Upper Limit Exceeded - MIL ON
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: E5CB2F4D2C7A671
Component: Lenkradmodul H02 0050
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 97
Mileage: 168321 km
Time Indication: 0
Date: 2003.02.27
Time: 17:52:59
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C4001513
Coding: 0000223
Shop #: WSC 03164 444 57801
VCID: DCBD0AA91F30269
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H06 0020
Revision: 06 Serial number: 50003421052901
Coding: FCFE7BDD1B2304
Shop #: WSC 09807 444 54400
VCID: 2649E84191FC2C9
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 105
Mileage: 168321 km
Time Indication: 0
Date: 2003.02.27
Time: 17:53:22
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 168322 km
Time Indication: 0
Date: 2003.02.27
Time: 00:04:49
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 168322 km
Time Indication: 0
Date: 2003.02.27
Time: 00:07:27
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 168322 km
Time Indication: 0
Date: 2003.02.27
Time: 00:30:16
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 97
Mileage: 168320 km
Time Indication: 0
Date: 2003.02.27
Time: 17:53:26
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 08256 444 00182
VCID: 254BEF4DECFA271
3 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 168566 km
Time Indication: 0
Date: 2003.03.02
Time: 06:34:46
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 137
Mileage: 168322 km
Time Indication: 0
Date: 2003.02.27
Time: 00:02:40
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 143
Mileage: 168394 km
Time Indication: 0
Date: 2003.02.27
Time: 21:58:12
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0060
Coding: 4071650
3 Faults Found:
01877 - Belt Height Adjustment Button (E333); Down
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 105
Mileage: 155876 km
Time Indication: 0
Date: 2003.02.27
Time: 00:03:21
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 105
Mileage: 155892 km
Time Indication: 0
Date: 2003.02.27
Time: 01:36:22
01876 - Belt Height Adjustment Button (E333); Up
006 - Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 105
Mileage: 155876 km
Time Indication: 0
Date: 2003.02.27
Time: 00:03:21
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000412500150
Coding: 0003734
Shop #: WSC 03164 444 58989
VCID: 1D3BC7ADC4AAEF1
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 105
Mileage: 168320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0080
Coding: 0028196
VCID: DEB900A1092C349
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040802220058
Coding: 0065086
Shop #: WSC 03164 444 83924
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H02 0020
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 105
Mileage: 138154 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:03
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 118
Mileage: 167186 km
Time Indication: 0
Date: 2003.02.27
Time: 04:53:44
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Reset counter: 105
Mileage: 141037 km
Time Indication: 0
Date: 2012.03.17
Time: 17:09:08
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000015402
Coding: 0010111
VCID: DDBB07AD042A2F1
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 105
Mileage: 168320 km
Time Indication: 0
Date: 2003.02.27
Time: 17:54:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 27
Reset counter: 145
Mileage: 168320 km
Time Indication: 0
Date: 2003.02.27
Time: 18:03:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Reset counter: 105
Mileage: 168320 km
Time Indication: 0
Date: 2003.02.27
Time: 18:07:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 74
Mileage: 167184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:08:51
Freeze Frame:
Voltage: 12.94 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Coding: 0000001
VCID: E2C134513D54109
1 Fault Found:
01310 - Level Control System Control Module (J197)
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 168328 km
Time Indication: 0
Date: 2003.02.27
Time: 17:55:18
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028196
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: DFC73DA50E263D1
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 26
Reset counter: 105
Mileage: 168321 km
Time Indication: 0
Date: 2003.02.27
Time: 17:55:52
Freeze Frame:
Speed: 0.0 km/h
Temperature: 15.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 168334 km
Time Indication: 0
Date: 2003.02.27
Time: 08:46:57
Freeze Frame:
Speed: 109.0 km/h
Temperature: 15.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3002273
Coding: 0000005
Shop #: WSC 03164 444 53905
VCID: E0C53E593058029
2 Faults Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: E0C53E593358029
End ---------------------------------------------------------------------
I dont think its the satelite radio bc I got it to respond or a second with the steering controls and everytime it boots up now it is in regular radio mode then stays on maybe 5 seconds and shuts down? Does the softwate upgrade just upgrade the control head or does i upgrade software in all the components? Viper told me he already has the newest upgrade on the control head I got from him was just wondering if all the other components could be running in the old software verison and thats why it keeps shutting down? Please help I need my MMI!!
Quick Reply: MMI update!!
