morning guys..quick question
Re: morning guys..quick question. Short answer NO...See inside..
What is covered-Section called SUSPENSION:
front axle sub frame, control arm supports, control arms(bushings subject to wear), wheel bearing housing, steering knuckles, front wheel hub, coil springs, stabilizer bars, stabilizer links, rear axle beam and support, stub axles, rear bearings and housings, rear springs.
What is NOT covered-Section called Wear Items (I'll just refer to those that are suspension related).
"This warranty does not cover any wear items, including but not limited to....tie-rod ends"
However if they "failed" then they are covered, see section on "wear clarification".<ul><li><a href="http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/product/certified_pre_owned.Par.0016.File.pdf">CPO weblink</a></li></ul>
Supercoupe
06-15-2008 06:34 PM
