My navigation is lost "literally"
My navigation seems to have amind of it's own. The display is showing at-least 30 to 40 miles off from real location. I done a vag scan and would like some help pin pointing the problem.Tuesday,27,August,2013,11:04:00:04768
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E26N003920 Mileage: 195600km/121540miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E4765051
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E53E54DB905E568827
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0110
Revision: --H01--- Serial number: 0059206
Coding: 0000002
Shop #: WSC 03109 444 58765
VCID: 25411A61ECF3A63073D
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 05136 000 00000
VCID: 224B017DFDDD510816F
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H07 0160
Revision: 01604507 Serial number: AUX3Z0E4765051
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BFE3956B014BD8B8B
Part No: 4E0 905 852 E
Component: ELV 1940
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 24470765E7C95F38643
1 Fault Found:
01973 - Seat Depth Adjustment Sensor (G378)
005 - No or Incorrect Basic Setting / Adaptation
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 346EO067533235
Coding: 0000103
Shop #: WSC 05136 444 69876
VCID: 204F0B75F3D1431800B
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000068117
Coding: 1052993
VCID: 1C373F85DFB967F8DC3
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E1 955 113 B
Component: ILM Fahrer H12 0210
Coding: 0143123
VCID: 3169FE31A83BFA909F5
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7165915
Shop #: WSC 00000 000 00000
VCID: 1B353C99DAB760C0D59
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Serial number: AUZ4Z7D2006279
VCID: 26431D6D91F5AD287A7
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q00009DF
Coding: 0532707
Shop #: WSC 05136 444 64396
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
2 Faults Found:
01219 - Rear Side Airbag Igniter; Driver Side (N201)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01213 - Belt Tensioner Igniter; Rear Middle (N198)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0310
Revision: 00H01000 Serial number: 90026050820049
Coding: 0012241
Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0420
Revision: D02 Serial number: AUDID3E4000122
Coding: 0048263
Shop #: WSC 07350 444 183238
VCID: 326BF13DAD3DC188E6F
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003055048028
Coding: FCFE7BDD1B7904
Shop #: WSC 07350 444 128344
VCID: 275D106996FFB420411
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
1 Fault Found:
011 - Open Circuit
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285F13559BE1BB5848B
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 355DY057546585
VCID: 387FC3154B412BD8D8B
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D
Serial number: 00000509400129
Coding: 0003477
VCID: 1D313281C4A36EF02BD
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0090
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040504090219
Coding: 0048702
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
2 Faults Found:
00985 - Right Tail Light (M2)
014 - Defective - Intermittent
004 - No Signal/Communication - Intermittent
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000015662
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000061847
Coding: 0010111
VCID: 1E33358DC9A575E8327
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0090
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 03129 444 84400
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000018
Part No: 4F0 941 329 B
Component: AFS-Modul links H01 0010
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396ES057510096
Coding: 0000002
VCID: 23450479E2C758001D9
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000008641
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 310228S2AX
Coding: 344530393135313035412056413033313032323853324158
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700032026
Coding: 0212127
VCID: DFCDC8890E2FBCE0F91
1 Fault Found:
02214 - Tire Pressure Warning
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000505200176
Shop #: WSC 12336 024 394758
VCID: 2D51E241B4039E70BBD
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 08720513300954
Coding: 0201308
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007500219
Coding: 0010900
End ---------------------------------------------------------------------
Thanks for any help
P.S. My sirius is intermitent to, so if you recognize the problem, please lt me know.
Chassis Type: 4E0
Coding: 0007773
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV 1940
1 Fault Found:
011 - Open Circuit
Coding: 4071520
1 Fault Found:
Coding: 0000103
Coding: 1052993
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
Component: SDAR
Coding: 0532707
2 Faults Found:
Coding: 0012241
Coding: 0048263
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
1 Fault Found:
011 - Open Circuit
Coding: 0015510
Coding: 4071530
Coding: 0003477
Coding: 0032364
Coding: 0048702
2 Faults Found:
Coding: 0000016
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000532
Coding: 0000018
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Coding: 0032364
Coding: 0212127
1 Fault Found:
Coding: 0032364
Coding: 0201308
Coding: 0010900
Thanks for any help
Water ingress causes rust as seen on C6 and D3.
Check the Nav for signal levels via MMI and VCDS.
There is also an antenna test you can run - will have to search archives for it.
Do you have any idea of what the antena signals are suppose to read and how to correct the problem if that is the cause?
Go to the back and make sure the DVD is on the level (horizontal and not vertical).
Sirius is also in the back, make sure all Optical cables are intact and the Fakra (antenna) connections for both of devices are not kinked anywhere.
Cheers,
Louis
There is a diversity board under the shark fin that tends to have issues - more so on the C than the D platform from what I've seen.
Ross-Tech can also provide guidance.
As Louis said it could be just a cable.
The common thread with most things electronical
bballfreak
9
04-14-2019 06:59 PM
