Need help with fault code of Steering angle sensor.
how are you guys doing? I have a 2004 audi A8L and its giving error code for the steering angle sensor. I used vag-com scanned the abs module and the error was:
01826 - sensor for steering angle(G85) - supply voltage terminal 30
000 --
Has anyone had this error before and how to fix it? What should i look for? thanks
000 --
I connect vag-com to check the steering angle and it stuck at -2.5*. It doesnt change at all while i steer. On my other audi it changed while i steer the steeringwheel. Could it be the steering angle got stuck somehow?
Go into the ABS Module via VCDS and then coding I and enter the code 40168. It should grant you access to basic settings. Then, with the steering wheel perfectly centered, go into basic settings. There should be a drop-down selection for steering angle sensor alignment. Select it, exit out, and it should be all good from there.
Steering Angle Sensor
abs/esp/stability light
Can anyone help me out
You have to complete login-11 then coding and then go to login to enter the steering angle sensor calibration aonce its accepted all that u go to basic settings and click steering angle sensor to actually calibrate it bht make sure the steering wheel is straight
2.7Avant
9
11-19-2008 05:03 PM
2.7Avant
VAG-COM Discussion
11-19-2008 05:05 AM
4Bidden
VAG-COM Discussion
01-18-2006 12:56 AM
