Need help -- w12 suddenly won't crank
#21
i did also try the battery disconnect for 3 hours and no change
#22
If Kessy fried (the coding related control system for keys) or programming somehow screwed up, I would guess it wouldn't crank either. There have been several of those on D3's if you search. Again, not in my own owners' experience so just flagging other possible areas to review. Presumably some fuse stuff in there too.
Finally, I don't think there is a fusible link involved, but do quick check anyway. The heaviest fuse like devices used on car. They are in the fuse box area by the battery. The handful of dog boned shaped stuff held down under nuts and terminals on both ends. Obvious when burned in middle since they are bare metal, open air stuff.
#23
...or it is jammed per the code... Mister Bally's 4.2 starter crapped out as one I can think of. If you have any straight line access path to the starter (I don't recall), try to thread a broomstick dowel or something similar up to it and whack on the end. Standard old American iron trick when they were visible under hood (ages ago) was to tap on them with a hammer. Same sort of thing with with solenoid (integrated on Audis for like 50 yeas now).
i really need a repair manual that shows all of the components involved in the crank signal once the key is turned to start narrowing this down. I have checked all of the obvious. Is there a way to check the kessy with VCDS? The car would randomly beep and say "Key not in vehicle" while driving, but not sure if that matters to this case, it has done that for months.
#24
thanks for all of the advice and help. I am convinced that the starter motor is not getting power, it does not even attempt to engage, I held the motor while someone tried to start the car and felt nothing. The clicking I hear under the hood is rhe various relays that fire up when you turn the ignition on, when I turn the key on and wait for everything to settle, the only additional noise is the fuel pump running when I turn the key to start. I can't really access the starter to whack it, but if it isnt getting power it won't matter.
s4TTq
23
11-25-2017 12:52 AM
Jesster8459
05-19-2010 07:42 PM
S4 in_lowplaces
12
10-22-2008 08:46 PM
