Need some emergency help, stranded
Hey guys, I am stuck on the side of the road in my 2005 a8 w12. I tool off from a stop and the engine died and will not restart. Scanned with carista and got cylinder injector circuit low for all 12 cylinders. 12 codes. Is there a common wire fuse or something that would make me lose power to all injectors?
I don' work with Carista, but just a general educated guess would be fuel pump. Injectors themselves are presumably powered straight through from ECUs and would need very little separate power. Higher draw pumps should have a relay and fuse set up; I never had to deal with fuel system on my W12 or older 4.2 so can only speak in general troubleshooting terms. though. There are two fuel pumps on a D3 port injected 4.2 or W12, both back in the tank. One is more a transfer pump, while the other is primary. Of course, there is the more basic out of gas question too. Have you checked that, and gauge? If you were on last part of tank, that could be that second transfer pump and in that case getting more fuel in tank might help. The tank is called a "saddle" design because it straddles the driveshaft and thus has two distinct low areas the pumps need to deal with, and why it can starve even with part of a tank if the transfer pump doesn't move fuel across. Counterproductive to fill to brim though if you will change pump(s), where having tank with less gas can make job easier.
More generally search on old posts about D3 fuel pump symptoms, whether older 4.2 or W12. Skip the S8 and later FSI 4.2 posts where there are also main high pressure fuel pumps that make them yet more complicated to diagnose.
Don't assume it is electrical either. Frankly the Carista code description is sort of pig Latin ambiguous to me. Code descriptions like these are among reasons I have had my doubts about that tool once you get deeper in. A "circuit" may mean electrical, but it could also mean a "system" in that context, if read just a little differently and as car techs and some other trades sometimes use terms like that. For example, a "cooling circuit." It doesn't help that their actual programmers are probably in Central Europe (Bulgaria if you dig) either, so there is also the risk the English translation they arrive at for the interface is really the exact set of words we would use. A VCDS scan may be more informative.
Don't assume strictly one ECU per 6 cylinders. The ECU's are split by function in some cases, not cylinders. Thus ECU 1 owns the fuel pump relay, while ECU 2 owns misfire detection as two examples. The ignition coils and injectors are split by the two ECU's across the heads/side of motor. Sort of: for the fuel. W12 wiring schematic shows one side (output signal) sources from respective ECU, while other side (power supply) sources from...the fuel pump relay.
Thursday,26,April,2018,23:58:38:55863
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
Ross-Tech: Home
VIN: WAUMR44E75N013033 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 25 28 34
36 37 38 42 46 47 4F 52 53 55 56 61 62 65 67 69 72 76 77VIN: WAUMR44E75N013033 Mileage: 174490km-108423miles00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Sporadic communication error 1000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E0 910 018 B HW: 4E0 906 018
Component: 6.0L W12/4V A ª0050
Revision: -------- Serial number: AUX3Z0DN755711
Coding: 0007773
Shop #: WSC 05140 444 64752
VCID: 1E652346ECBA7687604-804A7 Faults Found:
16660 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground
16645 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground
16651 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground
16657 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground
16654 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground
16648 - Fuel Injector #2 (N31)
P0264 - 002 - Short to Ground
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Readiness: 0000 0100-------------------------------------------------------------------------------
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 J HW: 09E 927 156 A
Component: AG6 09E 6,0L4V USA 0060
Revision: --H01--- Serial number: 0050081
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2A0DFF96A0F28A270CC-807ENo fault code found.-------------------------------------------------------------------------------
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD
Component: ESP 5.7 allrad H44 0330
Coding: 0007637
Shop #: WSC 02313 000 00000
VCID: 231312B2C7D85B6F4FA-8076No fault code found.-------------------------------------------------------------------------------
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0DN755711
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E9755ECE1EC8B76A8-800C Subsystem 1 - Part No: 4E0 905 852 D
Component: ELV 18345 Faults Found:
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Time: 15:43:1200183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Time: 15:43:1200190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Time: 15:43:3400191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Time: 15:43:3400668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 21:26:42
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303EC067522052
Coding: 0000203
Shop #: WSC 00000 000 08192
VCID: 323DE7F68822C2E7B4C-8066 Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000097113 Subsystem 3 - Serial number: 0123.04.130000000100010009ÿ Subsystem 4 - Serial number: 010009ÿ1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 23:39:30
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial number: 00000000058981
Coding: 1126865
VCID: 1B632A52FFA863AF87A-804E Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010 Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010 Subsystem 3 - Serial number: 898053000 Subsystem 4 - Serial number: HO06122004065A000000000031ÿ†89 Subsystem 5 - Serial number: 000031ÿ†898053000 000-SHO Subsystem 6 - Serial number: 000-SHO18112004065A00000000 Subsystem 7 - Serial number: 65A000000000169ÿ1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 23:41:26 Freeze Frame:
Voltage: 8.90 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0133123
VCID: 313FE8FA8D24F9FFCD6-8064 Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02313 No fault code found.-------------------------------------------------------------------------------
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD7102284
Shop #: WSC 00000 000 00000
VCID: 1C61294EFAA664978E0-8048No fault code found.-------------------------------------------------------------------------------
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D6019816
VCID: 2B03FA92AF08932FF7A-807ENo fault code found.-------------------------------------------------------------------------------
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Coding: 0007773
VCID: 1E652346ECBA7687604-804A6 Faults Found:
16663 - Fuel Injector #7 (N85)
P0279 - 002 - Short to Ground
16678 - Fuel Injector #12 (N302)
P0294 - 002 - Short to Ground
16672 - Fuel Injector #10 (N300)
P0288 - 002 - Short to Ground
16666 - Fuel Injector #8 (N86)
P0282 - 002 - Short to Ground
16669 - Fuel Injector #9 (N299)
P0285 - 002 - Short to Ground
16675 - Fuel Injector #11 (N301)
P0291 - 002 - Short to Ground-------------------------------------------------------------------------------
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041215
Shop #: WSC 56349 001 1048576
VCID: 25170CAAC9ECA55F21E-80701 Fault Found:
02003 - Driver Identification Control Module (J589)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11110100
Fault Priority: 5
Fault Frequency: 17
Reset counter: 202
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Time: 15:43:00 Freeze Frame:
Temperature: 34.0°C
Voltage: 12.42 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 241111AEC2D65C57360-80701 Fault Found:
002 - Lower Limit Exceeded - Intermittent-------------------------------------------------------------------------------
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012351
VCID: 65974CAA896C655FE1E-8030 Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080No fault code found.-------------------------------------------------------------------------------
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 H HW: 4E0 920 980 H
Component: KOMBIINSTR. VDO H53 0210
Revision: D04 Serial number: AUDID3DN000139
Coding: 0016203
Shop #: WSC 07434 001 1048576
VCID: 2C01F98EAA069417FE0-80781 Fault Found:
Freeze Frame:
Fault Status: 00000011
Fault Priority: 4
Fault Frequency: 3
Reset counter: 202
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:53:42
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 D
Component: Gateway H07 0040
Revision: 07 Serial number: 0500604A21028E
Coding: FFFEFFDD1B7904
VCID: 26150BA6B4EAAE47284-80722 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 242
Mileage: 174425 km
Time Indication: 0
Date: 2018.04.26
Time: 15:44:5002230 - Digital Radio (DAB) (R147)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:34:57
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV 1834
4E0905852D ELV 1834 5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 21:26:42
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000017 Serial number: 00000000023873
Coding: 0000000
VCID: 619F58BA9D44097F1D6-8034No fault code found.-------------------------------------------------------------------------------
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0013311
VCID: 2809059EBEFEB8371A8-807C3 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174439 km
Time Indication: 0
Date: 2018.04.26
Time: 20:17:1001575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 21:11:4201598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 23:13:18
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071658
VCID: 231312B2C7D85B6F4FA-80761 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 174488 km
Time Indication: 0
Date: 2018.04.26
Time: 05:28:03
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 E HW: 4E0 919 887 C
Component: MNS US H43 0560
Revision: 00000000 Serial number: 378L0047508386
VCID: 2F3BEE829B10EF0FDB2-807A1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 174425 km
Time Indication: 0
Date: 2018.04.26
Time: 15:59:54 Freeze Frame:
Bin. Bits: 0100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000432400059
Coding: 0003495
VCID: 1D67244AE1BC6D9F79E-8048No fault code found.-------------------------------------------------------------------------------
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0032492
VCID: 20191DBED6CE4077528-80742 Faults Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:3600532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040412030235
Coding: 0065214
VCID: 270B06A2B3E0B74F132-8072 Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 00203 Faults Found:
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 202
Mileage: 165216 km
Time Indication: 0
Date: 2018.01.15
Time: 14:24:2301134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 201
Mileage: 127984 km
Time Indication: 0
Date: 2004.03.25
Time: 03:57:3800985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 3
Reset counter: 202
Mileage: 152658 km
Time Indication: 0
Date: 2017.08.12
Time: 17:22:44
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000009522
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000053475
Coding: 0010111
VCID: 1E652346ECBA7687604-804A Subsystem 1 - Serial number: VK4978T0KWPE No fault code found.-------------------------------------------------------------------------------
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0032492
VCID: 20191DBED6CE4077528-80743 Faults Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Time: 15:43:0602111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000632
Shop #: WSC 39399 001 1048576
VCID: 1D67244AE1BC6D9F79E-80481 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Time Indication: 0 Freeze Frame:
Voltage: 12.42 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 629D57B69842126704C-80364 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Time: 15:42:5902233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Time: 15:42:5902234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Time: 15:42:5900070 - Starting Battery Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 242
Mileage: 174488 km
Time Indication: 0
Date: 2018.04.26
Time: 23:13:07
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396L-047501755
Coding: 0000002
VCID: 313FE8FA8D24F9FFCD6-80642 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:3900446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Reset counter: 242
Mileage: 0 km
Time Indication: 0
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000014794
VCID: 20191DBED6CE4077528-8074 Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 301009919Q
Coding: 344530393135313035412056413033303130303939313951
Shop #: WSC 05167 444 1800984 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 21:21:4902276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 21:21:5902274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 21:22:0902277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 21:22:19
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0032492
VCID: 1E652346ECBA7687604-804A2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700029488
Coding: 0202326
VCID: 5F9B5E42AB303F8F2B2-800A2 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 23:48:03 Freeze Frame:
Speed: 255.0 km/h
Voltage: 9.00 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 133
Reset counter: 202
Mileage: 172315 km
Time Indication: 0
Date: 2018.04.13
Time: 14:22:12 Freeze Frame:
Speed: 0.0 km/h
Temperature: 24.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000411270070
Shop #: WSC 12336 024 394758
VCID: 3431E1EE7236CCD7A60-80601 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:49
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 B HW: 4E0 907 383 B
Component: ANHAENGERELEKTR 003 0040
Coding: 0001001
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0032492
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720433401484
Coding: 0001308
VCID: 211F18BADDC4497F5D6-8074No fault code found.-------------------------------------------------------------------------------
Address 77: Telephone
Cannot be reachedEnd----------(Elapsed Time: 02:36, VBatt start/end: 12.6V/12.6V)-----------
Ross-Tech: Home
Coding: 0007773
P1923 - 008 -
Coding: 0000002
Coding: 0007637
Coding: 0410624
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 21:26:42
Coding: 3940576
Coding: 0000203
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 23:39:30
Coding: 1126865
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Voltage: 8.90 V
Coding: 0133123
Coding: 00000037
Coding: 00141886
Coding: 0007773
Coding: 0041215
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 202
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Temperature: 34.0°C
Voltage: 12.42 V
Bin. Bits: 00100000
Coding: 0530707
Coding: 0012351
Coding: 0016203
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 202
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:53:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 242
Mileage: 174425 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:34:57
Coding: 0410624
Component: ELV 1834
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 21:26:42
Coding: 0000000
Coding: 0013311
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174439 km
Time Indication: 0
Date: 2018.04.26
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 23:13:18
Coding: 4071658
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 174488 km
Time Indication: 0
Date: 2018.04.26
Time: 05:28:03
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 174425 km
Time Indication: 0
Date: 2018.04.26
Bin. Bits: 0100
Coding: 0003495
Coding: 0032492
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Coding: 0065214
Freeze Frame:
Fault Priority: 3
Reset counter: 202
Mileage: 165216 km
Time Indication: 0
Date: 2018.01.15
Freeze Frame:
Fault Priority: 3
Reset counter: 201
Mileage: 127984 km
Time Indication: 0
Date: 2004.03.25
Freeze Frame:
Fault Priority: 3
Reset counter: 202
Mileage: 152658 km
Time Indication: 0
Date: 2017.08.12
Time: 17:22:44
Coding: 0000016
Coding: 0010111
Coding: 0032492
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 201
Mileage: 174416 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Revision: AV1C1010
Coding: 0000632
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Voltage: 12.42 V
Count: 61
Coding: 0000004
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 174424 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 242
Mileage: 174488 km
Time Indication: 0
Date: 2018.04.26
Time: 23:13:07
Coding: 0000002
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 7
Reset counter: 242
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 21:22:19
Coding: 0032492
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Coding: 0202326
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Speed: 255.0 km/h
Voltage: 9.00 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
000 - -
Freeze Frame:
Fault Priority: 4
Reset counter: 202
Mileage: 172315 km
Time Indication: 0
Date: 2018.04.13
Speed: 0.0 km/h
Temperature: 24.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 242
Mileage: 174490 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:49
Coding: 0001001
Coding: 0032492
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 174480 km
Time Indication: 0
Date: 2018.04.26
Time: 22:54:36
Coding: 0001308
Got Vagcam and alldata, pointed to fuse 29 in the right fuse panel and found it blown. Replaced the fuse and the car runs fine now. Should I be worried about why it blew? I am planning to drive 2500 miles tomorrow out of town for a week
Fuse 29 does say fuel injectors from my owner's manual, but not anything I ever ran across. You may have to look at wiring diagrams to try to narrow it down. As I mentioned the W12 schematic says the power comes from the fuel pump relay, so not sure how that relates. That diagram does seem to say the power is all in common across the injectors, so an issue anywhere in the wiring on the power side could take all of them out together--or a fuse like that as you ran into.
You would not be able to see the injector wiring unless you take the whole upper manifold assembly off. Not that hard to do, but it takes a few hours and you should have a riser gasket for where it bolts up. But, a physical wiring issue could be on the way to the injectors too, like where you see the huge harness coming through the firewall on the passenger side, or the ECU's under the plenum. I don't recall anyone ever posting on this, so sort of needle in haystack. Do a visual of the wiring like back of motor near where heater hoses go through firewall, and remove the plastic plenum covers and look at ECU's and wiring there. You are unlikely to see much, but could be corner cases like rodent damage, obvious missing insulation or burns, etc. Look especially for any signs of water in plenum area, meaning the drains are clogged with debris. Good idea to blow that area out with an air hose and covers off anyway.
Other practical suggestions meantime. Since you have a full scan, now clear all modules. But, I sense maybe you already did? The scan shows tons of codes, many date stamped today. I noticed a few are older as I skimmed, but seemingly many or even most were today. Almost all current date codes can be a sign of a recent clear, hence why I ask. Also, did you wear battery down trying to start it?--lots of codes are power related even though in a handful of places listing voltages that I noticed it didn't seem seriously low in a difficult start situation. But you hit a quiesscent stage 6 code, which means the power management system reported at some point late on you basically pegged it and electrical system was on bare bones life support. See module 61--five times actually per the count, but I suppose that could be as close together as 5 turns of the key. As a nuance, by stage 6 it probably was turns of the key, since keyless start should drop out as it gets desperate. The first few stages are common in many D3 scans as they build up codes over time, but when it gets down to bone like that you want to understand why. With it now running, get your battery charged up. After that, scan it again and see what you get. Presumably the ECU injector short ones will resolve--if fuse is holding. If you show other shorts in any areas where wiring is in common, it might provide some clue. Another possibility as a long shot is you are having the not uncommon generally flaky electrical system stuff that can happen with D3's as a battery heads south. The deep in the red power management codes may be pointers too. Do you know age of battery? Did it just get worn down today cranking, cycling ignition, etc. or has it shown other signs of being tired recently? Before starting a 2500 mile trip, obviously I would want a dependable battery in any case.
FWIW, diagram showing stage 6 is end of the line:
SteveKen
13
05-31-2005 10:21 AM
MCbruges
04-24-2005 03:16 PM
