New A8L Owner - A few issues, ABS Sensor help needed first
Ok so today I went to look at an A8L with a less than market price. Came from the B5 and C5 platforms, not scared to fix a few things.
Test drive was great.. Ran VCDS saw a couple items. Memory seat issue, Nav issue and a known key issue. Drove about 50 miles today and while on the way home the ABS light /parking light came on. Ran a separate scan for that and found the following:
ABS issue, Full scan from earlier today below. Swapped the Rear Left and Front Right sensors to see if the issue was a sensor as these appear to be the same. No luck on that, turns out that the sensors seem to be good and there is a wire issue. Any recommendations on where to start, V that I should see at the sensor? Need this one solved so I can get emission test done will fail with lights on. Going to start the research on the rest of the items later this week. How can I test to see if I need a new harness (https://www.ecstuning.com/b-genuine-...ch/4e0927904b/)
Sunday,28,October,2018,13:22:11:16173
VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
Ross-Tech: Home
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Control Module Part Number: 4E0 910 517 B HW: 4E0 614 517 BC
Component and/or Version: ESP 5.7 allrad H44 0510
Software Coding: 0007597
Work Shop Code: WSC 02313 000 00000
VCID: 2240537EFDF0DC5AE3-8076
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Ross-Tech: Home
1 Fault Found:
The quiescent failures are from the battery going dead for whatever reason. Unless you know why that happened, start with a load test of the battery. These cars can chew through them and a bad battery makes all kinds of things get weird. Check the plug of the affected wheel sensor, it may just need a cleaning, corrosion wouldn't be a big surprise.
For the ABS issue: I have checked the sensor, cleaned it. Check the connections no corrosion. Going to see if I have the correct ABS wiring diagram and try to check continuity tonight for wires from sensor to module to see if there is a break in the wiring. Maybe there is an it is in the wheel well and repairable.
Below are the after reset codes showing up still, not sure why the ABS did not come back on. But it was coming on up till this scan last night. Will verify battery voltage this evening also.
For the Component Protection it seems like i need ODIS or the dealer to remove that. Hopefully they can do so. Would be nice to see the Nav Screen.
KM/Miles of scan below. 220640km-137099miles
Memory seat fault: 70868km - 44,035 miles
Navigation Fault: 220529km 137,030 miles Day/time of scan.
Battery Fault: 220533km - 137,032 Battery was replaced at 134,386 by Audi.
Sunday,28,October,2018,22:04:41:16173
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
Ross-Tech: Home
VIN: WAUML44E55N016482 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 72 77
VIN: WAUML44E55N0XXXXX Mileage: 220640km-137099miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E2560499
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 285441569BCC360ABD-807C
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Readiness: 0110 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0055679
Coding: 0000002
VCID: 3260A33EAD104CDA13-8066
No fault code found.
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory FS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071522
Shop #: WSC 20205 444 53401
VCID: 244C5566E7E4D26A91-8070
2 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 171
Mileage: 70868 km
Time Indication: 0
Date: 2008.11.03
Time: 09:19:09
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 70868 km
Time Indication: 0
Date: 2008.11.03
Time: 11:56:36
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503220072
Coding: 0064542
VCID: 2756426A96D23972B4-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 170
Mileage: 203905 km
Time Indication: 0
Date: 2015.12.06
Time: 14:17:48
End-------------------------(Elapsed Time: 03:04)--------------------------
Ross-Tech: Home
Coding: 0007773
1 Fault Found:
Coding: 0000002
Coding: 0007597
Coding: 4071522
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 171
Mileage: 70868 km
Time Indication: 0
Date: 2008.11.03
Time: 09:19:09
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 70868 km
Time Indication: 0
Date: 2008.11.03
Time: 11:56:36
Coding: 0064542
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 170
Mileage: 203905 km
Time Indication: 0
Date: 2015.12.06
Time: 14:17:48
I checked continuity between the wheel speed sensor and pins 30 and 16 from the ABS module, no breaks. So I assumed the issue was not with wiring and was with the module. Went to move wires, and swap the module when I found that 5-6 wires inside the loom have had the insulation disintegrate! multiple were touching. I did a temp fix for these to prevent them from touching, and codes were gone... Test drove this morning and they are back. Maybe my temp fix did not work. Time to bust out the heat shrink and soldering iron and try that. If it does not work then I will swap the ABS module after that.
This weekend I picked up a 2004 ABS module. 4E0 910 517 A HW: 4E0 614 517 E, Current is: 4E0 910 517 B HW: 4E0 614 517 BC Anyone know if this will work?
AudiWorld Wiseguy
This is the before wiring repair. I actually had to keep going down the loom as there was more wire issues. Got all the wires separate but ran out of heat shrink. Checked to see if I could clear the codes and No dice. Swapped in the other ABS module late last night, will finish with the heat shrink and report back. Anyone have a recommendation for heat protection? I was thinking putting some of this up to protect the module/wiring when done. https://smile.amazon.com/Thermo-Tec-...rds=Thermo-tec
Hi I have a 04 Audi A8l and have received that message before and I was able to clear it both times by simply putting the emergency brake on, then driving forward a bit and then disengaging the parking brake and then all the abs and park brake lights go away on the dash.
