Non-starting D3 A8
Non-starting D3 A8
Had this noise this AM, in the video. Car shut off when driving, now turns over but no start. No smoke, no leaking fluids.
Not sure. You think the timing belt blew? Seemed intact when I looked, but it may not be there anymore. Not sure what I was looking for.
Failed tensioner or water pump took out the timing belt, maybe? That was a very bad noise for it to make, I can't believe you drove it making that noise! If a car's engine is making strange noises you can not identify, do not drive it or run it. A mechanic might run it for just long enough to hear the noise if he doesn't see anything obvious, but no more than that. If you did take out the timing belt, the car is essentially totaled.
Remove one of the two covers (secured with two Torx head screws) at the front top of the engine beneath the "4.2 V8" decorative cover and post a pic of what's under there and one of us will offer another guess.
No pouring in a can of STP motor Oil Treatment to fix this issue I'm afraid......
Who knows, May not be timing belt related at all. That would be a good thing.
midds4
05-19-2007 05:06 AM
ColoradoBrad
12-08-2005 07:51 AM
