parking brake error
parking brake error
I have a parking brake error I set vcds to open replaced pads the closed then function test everything sound like it working but I have low pad warning and park brake flashing on dash
when I set parking brake it says "too steep" I tried to go in to Longitudinal setting but I dont know what Im doing there
Select]
[53 - Parking Brake]
[Basic Settings - 04]
Group 020
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The status of the Longitudinal Acceleration Sensor (G251) is now being displayed.
[Done, Go Back]
ok its 62 what does that mean?
why is it say too steep when Im on level ground
Group 020
[Go!]
[ON/OFF/Next]
[Done, Go Back]
The reading should be 0.0. That number is absurdly high and explains why you get the Too Steep! error. I'm surprised you're not getting a
failure code on the longitudinal sensor or at least an improbable signal. I'd suspect the senor is defective, knocked loose or a connector/wiring issue.
Fashizzkes84
15
08-14-2019 01:39 PM
Boosting1Bar
12-12-2001 08:05 AM
golem
Feedback
12-12-2001 07:00 AM
